Originally Posted by
Snail Style
Guys, not having DRLs won't cause failure of a RWC.
In regards to vehicle standards, the presence of DRLs on motor vehicles is not mandatory in Australia, as per clause 8.14.1 in ADR 13 - so you are correct on that point.
However, clause 4.2 and 8 in ADR 13 states that if the lamp is fitted and/or installed, they must comply with the requirements listed in the standard. For DRLs, this refers to paragraph 6.19.7 of appendix A in ADR 13, which states:
The daytime running lamps shall be switched ON automatically when the device which starts and/or stops the engine is in a position which makes it possible for the engine to operate.
The daytime running lamp shall switch OFF automatically when the front fog lamps or headlamps are switched ON, except when the latter are used to give intermittent luminous warnings at short intervals.
Thus, if DRLs are fitted and/or installed and don't function as per above, then it does not comply with ADR 13 - which leads to the next point...
Snail Style
Aslong as you have low beam, parkers and high beam then the vehicle is roadworthy, atleast in Victoria. Whether it meets ADR's still is a different story.
In regards to vehicle safety and roadworthiness, most states will have the following clause written somewhere in the regulations:
If a third edition ADR applies to the design and construction of a vehicle, the vehicle must comply with the ADR.
So in the overall scheme of things, if a vehicle is to be road-registered, it is a requirement that it comply with the ADR.
