Results 1 to 8 of 8
Thread: Tuning TDI Results
    Apr 2017
    belgrave victoria
    Tuning TDI Results
    Hi Guys
    I have done a lot of mod's to my alltrack in the year i have owned it
    Golf R brakes
    Pompanazzi Paint protection/correction
    Rear sway bar and linkages
    New 19 inch Brecia wheels
    ect ect
    Now for the big one a tune on the 135kw diesel motor and DQ381 gearbox
    Ok impressions of the motor as stock (135kw and 380 nm flywheel)(100kw and 285nm wheels)
    Power(kw) 1st power was good you felt it kick in about 3500 and pull to 4000 but was a waste to rev it harder than that as it ran out of puff and you could feel the car not accelerating and more even as you pushed the revs
    Torque(nm) Impressive would be the word i would use torque from 2000 to 3000 was very meaty and gave you a good push roll on acceleration in 3rd and 4th was good indeed
    There was a bit of a plateau between 3000 and 3500 before full kw kicked in but not to bad
    I would rate it as a good to very good motor with strong torque and a willingness to rev to 4k much better than my old 103kw/320nm mark 6 diesel which had good torque but not much in the way of power
    Tuned (approx 165kw and 470nm flywheel)(121kw and 360nm wheels)
    So a about 20% increase at the wheels which was very good
    Driving it felt like a new motor had been put in the car!
    Ok Torque 1st
    Nothing is noticeable before 2k after that tho wow oh wow the torque wall is huge all the way from 2000 to 3200 just feels like a huge rush pinning you back in the seat put's a smile on my face everyday
    Had a friend drive it and he said it "want's to go at 2k you can feel it wanting to go it's straining at the bit"
    Massive fun to drive the pull in 3rd and 4th is just amazing (5th as well but that's way over license losing speed)
    Power
    Tbh i expected the increase in torque from all the research i had been doing online
    What i did not expect was the power increase it makes the max power of the old motor at 2700rpm instead of 3500rpm
    also having nearly 50kw more atw at 4200rpm when the stock motor has run out of puff
    It revs like a insane nutter all the way to 4600rpm and makes power to there as well if you floor it in 1st away from the lights it launches so hard and makes this insane growl from 3500 to redline
    I get about 6.2sec to 100kph down from about 7.5
    The pull out of corners is great and in the wet i can get a 4 wheel slide going very nice indeed
    So in summery if your thinking about tuning your ea288 diesel DO IT the results are amazing
    Oh btw i got a tune not a box and run on a dyno to get before and after figures so no fudgery involved
    Also got my dq381 tuned at the same time to increase clamping on the plates and remove the torque limiter
    Fuel economy is quite good as well 6.8ltr/100 if i drive conservatively ,7.3 long term and 8 if i boot it everywhere
    I used Underground Performance in moorabbin (south east suburbs of melbourne)
    Highly recommend them did a great job
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Sep 2012
    Nice write up Kachingg. It does sound very impressive
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Apr 2017
    belgrave victoria
    Need to come have a drive Rooboy
    I am going on the next drive day on the 7/10!
    Apr 2017
    belgrave victoria
    Just a update on how the tune is going
    Had it for 30k now still runs fine and pulls hard
    Fuel economy is 7.3 around town and at 110kph cruise on freeway to Brisbane and back i got 6.1 ltr/100
    I took the newell hwy on the way back as its a single lane road a lot of overtaking of large multi trailer trucks was required
    4th gear is the go here pulls up to 145kph then when it changes to 5th the car rockets forward again have to lift off quick as 160+ is achieved in no time makes overtaking a safe easy exercise
    Still a happy camper
    Apr 2009
    What/who did you use to tune? I have a 110TDI with a bluefin to bump it up to 130kw/410nm. Much improved though yours sounds better again!
    2005 MkV Golf 2.0TDi 103 - DSG - Heated Leather - Tint - Audi 17" - Lowered - Bluefin Tune.
    2016 MkVII Golf 2.0TDi 110 - Wagon. Fully Optioned. Lowered on Eibachs. RS3 Black 18s. Mk8 Head Unit. VCDS Tweaks - Bluefin Tune
    Quote Originally Posted by Sage View Post
    He said Underground Performance at the bottom of his 1st post. I have also recently used the same place to tune my SQ5 TDI.
    Apr 2017
    belgrave victoria
    I used underground performance in moorabbin victoria
    They did a great job
    Mine has more power because it is the gtd motor making 135kw instead of 110kw
    Bigger turbo and injectors ect ect
    Great open road car just eats the miles up and overtaking is a breeze
    What DQ381 tune did you get ? TVS ?
    RS
    R
