Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 81
Thread: Traffic Reports with Discover Headunit
  1. #51
    That's for Audi MMI does it work for MIB also?
  2. #52
    kamold: Perhaps I wasn't clear - I don't know, I'm suggesting that OP might try.
    The App of course is purpose written for a mk7 - so that should work
  3. #53
    Sep 2017
    Traffic info availability in 7.5 golf
    Hi...this may have been answered before, but should the traffic info work in the 7.5 golfs?
    i have enabled the TP option but the TMC looks to be crossed out. Is this available in Oz? I understand the TMC messages aren’t the best...they typically tell you of an accident after you are caught in them. Ideally the same traffic congestion colour features in google maps would be useful but I’m guessing this isn’t possible as we don’t have car-net over here.
    MY18 Golf R Wolfsburg Oryx White
    MY10 Skoda Octavia RS Race Blue...sold
  4. #54
    May 2013
    I avoid the VW nav and use Google Maps or Apple Maps which does the traffic stuff by default.
    Sent from my iPhone using Tapatalk Pro
    MY08 Mk5 GT Sport - sold
  5. #55
    Mar 2010
    The TP option works in mk7 GTI so I assume it should work in the mk7.5 cars....
  6. #56
    Sep 2012
    It's working in my 7.5 Alltrack
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  7. #57
    Dec 2015
    NSW
    Quote Originally Posted by Mattlock View Post
    I avoid the VW nav and use Google Maps ... which does the traffic stuff by default.
    +1 for Andriod Auto
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
  8. #58
    Apr 2014
    Albany Creek, Qld
    Quote Originally Posted by Schvengb View Post
    Working from memory here but don't you have to enable both RDS and TP to get traffic to work???
  9. #59
    Hmm............... TP should be active on the 7.5 Golf. Perhaps it hasn't been set-up properly in the FM radio section of the MIB unit. You need to place a tick in the Traffic Program box (see below). If this is done correctly, you should see TP appear on the FM radio screen (see below)
    As for enabling TMC, which is an entirely different thing - you will need access to a diagnostic cable/dongle to do this if its not enabled from the factory. I've put the tweak instructions for TMC HERE if you have a VCDS cable
    And the instructions for the tweak using OBDeleven are as follows:
    You will also need to ensure that Radio Text and RDS is activated (see below). This is because TMC in Australia uses a sub-harmonic of the RDS frequency on the FM band. RDS is the carrier frequency that populates the "textual' information on the FM band screen (see below)
    If all goes well you should see the final screen shot below when you press the TRAFFIC button (sorry for the fuzzy image)
  10. #60
    Sep 2017
    Thanks DV52,
    interestingly I dont have the same advanced options as the screenshot...no rds tick box.
    Might be related to tmc not being enabled though. I’m gonna check with the dealer to see if it in theory was supposed to be active.
    cheers
