Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 81
Thread: Traffic Reports with Discover Headunit
  1. #21
    CandE; Hello. Not sure if you are aware, but RDS stands for Radio Data System. Just as a suggestion, have a look at the code-string on your MIB and in particular note the setting for Byte 13, Bit3. If the long coding helper is the same as mine below (which is from a MIB1), Perhaps this setting cab help you with the problem?
    I made this change as suggest by Don, thanks for that, and now have RDS option in menu, but still not receiving any traffic reports.
  2. #22
    Quote Originally Posted by CandE View Post
    What software version is on the unit?
  3. #23
    I will check tomorrow and report back. Might have to get it updated as suggested and see how that goes.
  4. #24
    CandE: Good- at least you now have RDS! The problem may well be the SW version as per Kamold's post, but one last suggestion that is an easy try is to reset the infotainment unit.
    Not sure if you know this procedure, but just hold down the on/off button on the radio until the unit switches off and keep holding down the button until it switches on again.
  5. #25
    Apr 2011
    When I did this on my MIB1, the initial value was 0. But on my mate's Golf MY15, his was something like 65535. I haven't changed his yet, but did anyone find changing from this initial value work? Or does it need a software update to his headunit?
  6. #26
    Jun 2016
    Melbourne, Victoria
    So my partner went to VW today, MY16 110 Highline. Hardware H24 and Software 0245.
    No MIB2 updates available (Apparently one is coming...) so traffic obviously still does not work. Have not tried the POIs however I'm assuming they won't work either.
  7. #27
    Need to do some research and find out how the software version numbering works.
    Appears to be different for different regions.
  8. #28
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by SimoHDK View Post
    MY16 92 TSI with MIB2 - H25.14.78 Software 0624. Updated early August. Traffic 1024 coded and custom POIs work fine.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  9. #29
    Jun 2016
    Melbourne, Victoria
    My personal car, MY16 Golf R is:
    Hardware: 820
    Software: 0624
    Traffic and POIs work fine.
  10. #30
    Quote Originally Posted by Eaglehawk View Post
    Eaglehawk: explanation of numbering follows:
    Originally Posted by zloybob
    hello Maybe i can help u with TMC
    1024, 65535 etc its value for various settings (This can be seen in the firmware file)
    65535 - TMC OFF
    1024 -
    SUNA Traffic (Intelematics)
    0 - dev options
    32771 online traffic + VW TMCPro
    Australia uses SUNA, I've seen lots of UK admaps that have 32771 setting. In answer to your question, I have changed a couple of units with 65535 and it has worked OK - but I needed to reset the MIB unit in each case and wait a while before the Traffic table was populated . On one of the cars, it didn't work until the owner started the car the next day - go figure!!
