Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Tips for wearing in my new Mk7?
    Jul 2015
    Melbourne, Australia
    thrashed my 7R as soon as i left the dealership (oil at 80deg first) and have driven it semi hard on the daily, small bursts here and there on the way to and from home. Car has now 55,000ks in almost 2 years, and its been great. Fuel Efficiency sits around 500-550 to a full tank of BP 98.
    15 Golf R MK7
    Manual
    APR Tuned
    Dec 2010
    Helensburgh
    Yes, Golf PP got redlined out of the dealer's driveway as did our new Tiguan and neither has used a drop of oil between services but then the Tiguan has not got a lot of K's on it yet. All our race motors got the same treatment with no problems and remember that it has warranty if something goes wrong.
    May 2013
    Quote Originally Posted by mrmomoz View Post
    I always wait until the oil temp is north of 80C. I have at least 1 point on each drive where I push it hard.
    Never got close to 500-550km on a tank unless I do a lot of freeway driving. Typical daily use sees me around the 450-475km mark.
    Sent from my iPhone using Tapatalk Pro
    MY08 Mk5 GT Sport - sold
    May 2017
    I took it on a nice run into the hills. Sadly my GPS took me up the freeway to begin with (but it is a very steep freeway). Came back down through the twisties and had awesome fun, handles very nicely.
    Apr 2017
    belgrave victoria
    I remember that freeway climb from 15 years ago (last time i was in s.a) it is quite steep
    Hope you enjoy your golf they handle vry well even in a non sport model
    Jul 2015
    Quote Originally Posted by Mattlock View Post
    What drive mode do you use? Mines set to individual, [Springs on comfrot, rest on Race] great for daily use, and keeps exhaust flaps open, for the crackle and pop on decell. How do you find your JB1? i cooked my stock clutch in 4,000ks as soon as i got the tune done by apr. now currently running a carbon ceramic kit, with a single mass flywheel. Dyno run at 224 all wheel kilowatts.
    15 Golf R MK7
    Manual
    APR Tuned
    Dec 2010
    Helensburgh
    What do you have to do to wreck a clutch in those K's?
    May 2013
    For most of my daily use, I use Individual with suspension and steering on Comfort, engine on normal and a/c and sound on Eco. It keeps the exhaust sound down when I leave the house early in the morning.
    When I want to have some fun, I switch straight to Race!
    Love the JB1, it complements the engine really well. I run it in a clutch-protecting map (6, I think) to reduce the intervention in the lower gears/rev range which does develop a bit of a non-OEM style bump around 3k RPM.
    Car currently has 20,400km on it. I have always felt the stock clutch is not very good (so easy to slip it) so I expect I will replace it in the next 6months and then I will switch the JB1 to something a bit more potent!
    May 2013
    Quote Originally Posted by Ozsko View Post
    I suspect it was the APR tune contributing. The manual clutch isn't great. It's quite light and very easy to slip. I've removed the helper spring from the pedal which improved some of the dead feeling but the real culprit is a restrictor in the clutch line as it seems to make the clutch slower to engage than you're expecting. There is an ECS Tuning alternative or it is possible to drill out the restrictor from the OEM plastic part - I've not been game to do either yet.
    I notice that I have to be careful on fast upshifts as it's very easy to have the gas on before the plates bite. I encounter it most when doing Hill starts and the car releases the handbrake before the clutch bites, causing you to shoot backwards or dump it with a load of revs on to catch it - which makes it slip.
    As my driveway is a 25% gradient, it's a right PITA. I either shoot back out into the road or end up in the garage with a smelly clutch.
