Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 157
Thread: Things you don't like about your MK7
  1. #21
    Nov 2009
    Quote Originally Posted by Nauend View Post
    Just over 1000 kms travelled so far and the only real complaint I have is that slow spot before the RPMs hit 1500 and the turbo kicks in.
    Uh that slow spot just before 1500rpm is called idle.
    Volvo S60 RD T6
  2. #22
    Jun 2013
    Act
    Quote Originally Posted by thezoneR32 View Post
    lol. Perhaps a better way to describe it is there is an obvious hesitation when accelerating from a stopped position. Experienced it on the three grades of Mk7 that I test drove and still getting used to it. The falcon I used to drive would stick the boot in straight away without hesitation, so I expect its just a matter of me getting used to the smaller 1.4 turbo combo (as well as front wheel drive).
    May 20 - Nov 19 MY20 Tiguan 162 TSI
    May 16 - Apr 16 Mazda 3 Sp25 GT - 2020 hail storm write-off
    May 13 - 2013 Mk7 Golf Highline.
    May 10 - 2009 Falcon G6E with beige leather.
  3. #23
    May 2013
    Quote Originally Posted by Harrydhillon View Post
    Hey
    Pt3: safety first
    Pt4: agree re the cruise control but you get used to it after a while
    Pt 5: daylight running lights are meant to be always on with the ignition - increase visibility on the road.
    Pt 6: that's a safety feature in most European cars - wont drain the battery that quick as it only operates at low voltage - if I remember correctly it only works in the dark - stops someone running into your parked car in the dark
    Harry
    MY13.5 Red Polo GTI
    Pt3: not having this feature makes starting the car more dangerous? How so?
    Pt5: would be better if this was an option, if it says OFF, I expect it to be switched off, common sense would seem to indicate as much. If it comes on with AUTO on, I wouldn't have a dislike of it.
    Pt6: Nope, happened in broad daylight when I parked outside my house to wash the car and was wondering why the bloody hell one side was on and not the other.
  4. #24
    May 2013
    I know exactly what you're talking about. There is a subtle but noticeable lag from a standing start before the turbo suddenly kicks in. I've adapted to it by easing up on the accelerator just before the boost so it's a more even acceleration, otherwise, it's quite a jerky take off. Another quirk of the DSG gearbox, I'm led to believe. Even a crappy underpowered Hyundai had a more responsive and even acceleration. Having said that, after the takeoff, the rest of the drive is really quite smooth and enjoyable.
  5. #25
    Sep 2010
    Quote Originally Posted by exzibit View Post
    With the manual you have the advantage of giving it a few more revs as the clutch is released on any reasonably brisk start and you're immediately in that torque band. The "softness" is only noticeable when really pussy-footing it.
    Nov '15 Polo 81TSI manual white
  6. #26
    Sep 2010
    2. The way you have to turn and twist your wrist to get the ignition key to start. All other cars I've driven and owned the turn is a 90 degrees turn. On the VW, it's almost 180 degrees.
    Actually 90 degrees in the "on" position and about 120 degrees to engage start. What I do find annoying is that the 12 volt power outlet doesn't work unless the ignition is on. Can sit an listen to the radio with the ignition off but the phone can't be charged. Jap cars have a useful key position called accessory.
  7. #27
    Nov 2009
    This will most likely be the DSG. You'll develop a love/hate relationship with it. Hate it because it makes you feel like you dont know how to drive anymore,/love it because once you learn its nuisances you will be quicker than anything else around you.
    Volvo S60 RD T6
  8. #28
    Mt Cotton
    Whilst not a current Golf owner I found out in Germany from a dealer that because there are many old towns with very narrow streets drivers can leave either side indicator tail lights on so other drivers can see them in the dark depending which side of the road you park on .DLR lights are my pet hate again in countries like Europe and Northern America [in some Canadian areas its mandantory for the headlights to be on all the time ] because of the weather conditions foggy drizzly days it is a safety feature . Here in Australia they should be optional it would be so simple for the headlight switch to have an "off" position , I suppose my dislike is some of these cars with massive LED displays on during the day which just sceams Look at Me Look at Me .
  9. #29
    May 2009
    North East Victoria
    Apparently the wiper smear problem is widespread as it has also been commented in the UK forums. Apparently the right side wiper is too long? thus the arm isn't firm enough to push it against the screen.
    I guess the slow take off is what Wheels mag described as doughy accelerator, a bit wooden like the Mercs.
  10. #30
    May 2013
    New Farm, QLD
    Correct, I drove my bosses BMW 1M DSG and I had the same sensation as you describe so it's not a MkVII problem more a symptom of driving a DSG.
    Golf MK7 | 110 TDI | DSG | Highline |Limestone Grey | 'Rotary' Wheels | Driver Assist
