Results 1 to 10 of 13
Thread: Sunroof - flat or tilted?
    May 2020
    Canberra
    Is the sunroof supposed to be nice and flat along the roof?
    My car had some work done and it dips down, and I was sure it used to be nice and flat.
    Maybe I'm remembering wrong?
    It's going back on Monday as the groaning type noise happens quickly on the highway going over sections of road, and maybe they need to put it back to flat as well.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
    Photo to show what you mean exactly?
    My sunroof is flat and sits nicely aligned with the shape of the roof.
    May 2020
    Canberra
    I'll grab a pic soon.
    May 2020
    Canberra
    Not sure if it's hard to tell but it dips down at the front and obviously is a bit higher at the back
    Here is mine. Yours does look like its not aligned correctly at the front. You can fix it yourself easily if you have some basic tools, otherwise get the VW dealer to do it for you. I cant remember if they use Torx head screws or normal screws on the adjustment tabs, ill try to remember to have a look after work.
    May 2020
    Canberra
    Thanks. I was thinking, this used to be perfectly flat. When I mentioned it someone said it is designed like that for wind resistance, or something like that, now that it was tapered.
    It's going in on Monday so I will mention.
    For knowledge sake, it would be cool to know where the adjustments are made.
    Quote Originally Posted by genebaby View Post
    It should be flat when closed and inline with your roofline as best as possible.
    The front adjustment tabs are accessible from inside the car. They are on either side of the sunroof towards the front.
    With the rear ones, tilt the sunroof up, then if you stand near the back of the car and look at the sunroof, you will see the screws on either side of the sunroof which are exposed once you tilt the sunroof up. If you loosen the screws, you can then adjust the sunroof (perhaps 1cm in total, up/down) to get it sitting flush with the roof.
    I will try and get some pics for you.
    Front
    Rear
    May 2020
    Canberra
    Thanks, no idea why they left it uneven.
    May 2020
    Canberra
    Well, it went in today and I asked them to make it flat again but they wouldn't do it as it was in spec and matched other cars, they said.
    I can't believe it, it was flat before they worked on it and I just wanted it back the way it came.
    This must be what VW mean when they tell us to expect a little more.
