Citroën DS4 Racing
Audi A3 / S3
Mercedes-Benz A 250 Sport
Volkswagen Golf GTI
Other (please specify)
still not convinced, especially the rear - looks like a previous model corolla with a cheap body kit bolted on. And what's with the extruded mesh in the lower front section, couldn't they afford anything else? Stands out like a povo pack model. And the side panels/doors have Hyundai pressed all over them. And what's with the red speed stripes in the lower front and rear sections? Looks very odd IMO, even more so than it does in the GTI.
But then again, the golf possibly could do with a tad more flair?
(removed red mk6 images to avoid confusion, thanks for pic of red mk7 alebonau)
Once had a Red mk6 GTI + DSG + leather + sunroof + mdi + towbar
now have a gorgeous Red Merc A250 AMG Sport
looks will always be down to personal preference, ofcourse something you like others wont. not sure what your posting pics of a mk6 golf about. we're comparing to the mk7 gti. as I said before I would rather keep my mk6 gti then get a mk7 not convinced mk7 is worth updating to. unless your suggesting the same.
heres a red one in mk7, probably not the most flattering angle or shot though !
or were you after one of these ??its red hehe
Had an uncle that owned one, his fault I'm driving Vw's today. It was the ducks in those days for sure.
The reports from overseas on the A Class haven't been totally positive. They focus on the poor handling/ride compromise. The ride is appalling in all models apparently and gets worse as you move to the sportier models.
Seems there's a sus upgrade for the Sport though: AMG Sport cars also get thicker anti-roll bars, stiffer springs, firmer dampers, variable rate steering and uprated brake discs. The result is a fine handling car. Chuck it into a corner quickly and the car remains almost flat, and you have to try very hard to get the front end to run out of grip.*
All this means you can fling the A250 AMG Sport around a twisty road with great confidence, although there is a trade-off over the standard car in terms of comfort, as the ride can get quite bumpy on broken surfaces.*
If you can cope with an even firmer ride still, for an extra £1,920 you can opt for the ‘Engineered by AMG’ version of the A250, which takes the handling up another notch with an even more aggressive chassis set-up. This car is identified by its unique pin-style grille and red brake calipers
and no AMG badge? Rip off![]()
