Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: Soundaktor
  1. #31
    I've just coded one for a customer down to 60% and sounds much better (on a Mk7 R)
  2. #32
    Central VIC
    ^ JDM, would you be able to share the coding required? I would like to have my dealer adjust my Mk7 R but this will be a first for them so much easier if I go to them and say "this is what you need to do, 5 minute job". Cheers
  3. #33
    Central VIC
    OK, here it is (courtesy of Golf mk7 FORUM):
    Go to:
    - A9 Struct. Borne Sound
    - Adapation 10
    - Select "channel of structure borne sound " (only choice)
    - Std value 100% - change to the value you want stored in % (60% has been suggested as a good happy medium, adjust to 0% if you want no noise/mini vibrations).
    - "Use change code for change approval" (not sure what this means??)
    Now to find someone with a VCDS cable or trudge back to the dealer...
  4. #34
    Quote Originally Posted by andrew7 View Post
    Haha yeah thats ok, its a really simple job, they can scan the vehicle and go to the borne sound control module (called -J869-) and in there they can code the volume as a percentage, 60% works good at that but its upto you what level youd prefer
  5. #35
    Go to:
    - Adapation 10
    If you're near Rockdale (NSW) i can do it for you
  6. #36
    May 2012
    Chadstone, VIC
    Soundaktor
    Anyone in Melbourne with VCDS and micro CAN who can assist with a simple coding of the soundaktor synthesised engine noise for Golf R mk7? Would really appreciate it. I have the instructions so should be pretty simple.
  7. #37
    Mar 2009
    Melb
    I have Micro-can. SE suburbs
    PM me
    Tig 162 R-Line; Audi TT
  8. #38
    Jul 2012
    Sinagra, Western Australia
    I'm out west, so if you want to get stabbed and have a few other things switched on then just drop me a PM. Only thing I haven't gotten to work so far was the XDL adaption in the brake electronics.
  9. #39
    May 2012
    Chadstone, VIC
    Thanks guys, appreciate the shout out. I'm in chaddie so MrGee I'll PM you shortly
  10. #40
    Jun 2011
    Sydney NSW
    There are a whole lot of F1 teams that will be in the market for a sound generator!!!!!
