Originally Posted by
Paul_R
I finally got around to disconnecting mine. If anyone has difficulty accessing the plug, after removing the rubber strip and 3 clips, there is a further step which improves access.
There is a black metal plate at the top of the firewall that can be removed too. Anyone who had a Mk 6 will know what I mean. Remove the 4 big disc screws holding the insulation onto the front of the firewall. Then remove the nut holding the plate down at either end near the strut tops. The whole thing will come up and out giving very easy access to the Soundaktor. Probably most useful if you want to reconnect the plug or get at the wiring easily to put a switch in it. I may get around to that eventually.
Paul: Hi. Just a quick question about removing the soundaktor -please.
If you physically disconnect the wires to the Structure Borne Sound control unit, won't you get an error message reported on the car's diagnostic (i.e. the autoscan report in VCDS and/or the error report in the dealer's ODIS system)? I don't have one of these units in my mk7, so I can't test it.
My second question is: rather than removing the wires from the control unit, would it be preferable to physically disconnect the two wires to the vibrating mechanism (it's really not a speaker) that connects to the front windshield? My hunch (again I can't prove it because I don't have a soundaktor) is that this might (?) not produce an error message.
