Change the filter Will be less than $99
I've had my car for over 6 months now and it's due for its 15k service. For the last few weeks I've been noticing that the aircon is starting to smell upon startup for around 30-60 sec. I asked the service people and they're asking me for 99 dollars for an antibacterial spray. Do you know what can be the other reasons for this? Because for a spray... 99 dollars is abit too much.
Oh and they said it's because of the dead bugs building up in the filter.
Thoughts?
GTI PP Mk7
My grandma used to say...
This has come up numerous times before. Here's a discussion on the DIY.
DIY Getting rid of smell from air conditioning system
A tip to reduce it is to is to turn the aircon off a few min before reaching your destination to ensure the ducts aren’t too cool and will cause any condensation once you stop.
I find a new pollen filter snd glenn 20 does the job better.....
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Thanks a lot guys. Really helps. Sorry for not searching, cause my car is in service and I need a pronto answer hehe
GTI PP Mk7
https://www.carcareproducts.com.au/p..._klima_cleaner
https://www.carcareproducts.com.au/p...ma_cleaner_etu
Either of these get ride of any smell in air con, a lot cheaper than $99 service
My technique is simple and cheap and it seems to work OK.
- Buy a can of "Glen20".
- Fit a nozzle tube to it (the type that you find on cans of spray lube).
- Turn the fan on to the lowest setting
- Put the tube down the vent on each side of the car just behind front wipers (the black plastic vent)
- Empty about a quarter of the can on each side
- Do it just before the Hot season (about now)
Just bought the Mann filter from amazon it fixed the problem straight away. Was easy enough to change over.
Mann-Filter CUK 2939 Cabin Filter With Activated Charcoal for select Audi/ Volkswagen models:Amazon:Automotive
