Results 1 to 10 of 17
Thread: Smelly aircon
    Mar 2014
    Perth
    Smelly aircon
    I've had my car for over 6 months now and it's due for its 15k service. For the last few weeks I've been noticing that the aircon is starting to smell upon startup for around 30-60 sec. I asked the service people and they're asking me for 99 dollars for an antibacterial spray. Do you know what can be the other reasons for this? Because for a spray... 99 dollars is abit too much.
    Oh and they said it's because of the dead bugs building up in the filter.
    Thoughts?
    GTI PP Mk7
    My grandma used to say...
    Pacific Paradise QLD
    Change the filter Will be less than $99
    Oct 2009
    Mitchelton, Qld
    This has come up numerous times before. Here's a discussion on the DIY.
    DIY Getting rid of smell from air conditioning system
    A tip to reduce it is to is to turn the aircon off a few min before reaching your destination to ensure the ducts aren’t too cool and will cause any condensation once you stop.
    Mar 2013
    Brisbane QLD
    I find a new pollen filter snd glenn 20 does the job better.....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2014
    Perth
    Thanks a lot guys. Really helps. Sorry for not searching, cause my car is in service and I need a pronto answer hehe
    GTI PP Mk7
    Sep 2012
    Wonga Park, VIC
    https://www.carcareproducts.com.au/p..._klima_cleaner
    https://www.carcareproducts.com.au/p...ma_cleaner_etu
    Either of these get ride of any smell in air con, a lot cheaper than $99 service
    Central VIC
    Quote Originally Posted by donweather View Post
    ^ This. Always done it (even 30 seconds), never an issue.
    My technique is simple and cheap and it seems to work OK.
    1. Buy a can of "Glen20".
    2. Fit a nozzle tube to it (the type that you find on cans of spray lube).
    3. Turn the fan on to the lowest setting
    4. Put the tube down the vent on each side of the car just behind front wipers (the black plastic vent)
    5. Empty about a quarter of the can on each side
    6. Do it just before the Hot season (about now)
    Jan 2013
    Just bought the Mann filter from amazon it fixed the problem straight away. Was easy enough to change over.
    Mann-Filter CUK 2939 Cabin Filter With Activated Charcoal for select Audi/ Volkswagen models:Amazon:Automotive
    .....A tip to reduce it is to is to turn the aircon off a few min before reaching your destination to ensure the ducts aren’t too cool and will cause any condensation once you stop.
    That makes no sense. The functioning AC is what removes the moisture from the system. To have the best shot at no smell is to have the AC on all the time. With the auto system that is easy, set the temp you want and leave it alone.
