Yes, but as it is cool inside the system, when you turn off the car, the cool interior surface of the air con assembly draws in moisture, which sits for quite a while and a perfect environment to harbour mould/mildew. If you turn off the a/c a few mins before stopping the car (but not the total system) then the warmer air helps bring up the system to outside air temperature so when the car is turned off, moisture won't accumulate on the interior surface of all the aircon system.
Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
The heater core is after the evaporator. So how will this help?
2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
2016 Skoda Superb 140TDI - Family Members
2013 VW Amarok TDI420 Highline Auto - Family Members
I've had the same problem after 25,000km. I always try to turn the air-con off and max fan 1 min before I arrive at my destination (turning the heater up on a hot day really isn't ideal!) but couldn't prevent it.
I took our my cabin air filter behind the glove box then vacuum the accumulated rubbish and it seems to have helped significantly.
Maybe do the same or buy a new cabin filter.
quick google search, cabin filter costs around $35
https://www.sparesbox.com.au/ryco-ca...106211-rca270c
Except buy a carbon-activated one, instead of a plain paper one.
The plain ones are just leaf catchers and nothing more.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
True, and I find it genuinely makes a different in pollen reduction.
