Pretty common issue here too, but I dont believe there was a recall in Australia.
As far as I know, America was the only country who issued a recall.
I recently had the warning that says “Error, leave vehicle in P position” while driving and from my research it seems to be a common issue overseas. They even had an official recall for a compliance recall on shift lever micro switch in the US. I was wondering if there was one as well in Australia or if anyone had it fixed out of warranty.
MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
MY11 MK6 GTI Black - Leather, Sunroof etc.
MY17 MK7 Golf 92 TSI
MY18 Mazda CX-9 Touring AWD (For sale)
Might be worth a try - assuming this is for your MY2017 92TSI Golf? Could argue this part should last longer than 5 years. This part has luckily not failed (yet) in my 2015 Mk7 GTI.
Otherwise, seeing you are in Melbourne, you have a decent selection of VW specialist mechanic workshops that could potentially do it for you.
fixed this issue myself, using part 5Q0713128A there is another part depending on your model - mine is 16 Mk7, watched video Mk7 Golf R - Error: workshop! Only leave vehicle in Position P - Repair kit walk through - YouTube - mine was the other type so used info here https://static.nhtsa.gov/odi/rcl/201...9V615-0044.pdf - had to use a combination of both methods to get to the shifter but an easy repair, took about an hour and a half. Part was $137.50 from the stealer, cheaper if you get it from overseas
Thanks for the detailed reply, I only saw it now. I haven’t got around to it yet so I’ll look into that video as well - I’ve watched one previously but it looked like it needs a lot of trimming to be removed to replace it.
I’m getting other warranty issue looked at on my Tiguan in 2 weeks’ time so I’ll ask them if they could do it out of warranty just in case - would this be considered part of 5 year transmission warranty? Being MY17 it only came with a 3 year warranty.
Shifting lever 10-15 times trick didn’t work for me but having Auto start stop on helped a lot for some reason until recently so now I need get it sorted.
Our 2016 Golf is exhibiting this issue now. Going to print this off and show the dealer:
Compliance Recall 37L5 / Shift Lever Micro Switch
https://static.nhtsa.gov/odi/rcl/201...8V464-0189.pdf
2010 Golf TSi & Polo GTI White MY12.5 - VIC
