Results 1 to 10 of 19
Thread: Service Interval Golf R 7.5
    Sep 2024
    Canberra Australia
    I recently purchased a 2020 (20MY) Golf R7.5 which now has 25,500km on the clock. Still working my way around the car. Recently a message came up indicating a oil service was due in 28 days, now down to 13 days.
    Clearly this is based on time since a previous service rather than kms travelled.
    So do I need to act on this indication or wait for the kms to tick over. I know the car had its post delivery service when new but do not know when any interim service was carried out. As I said, I am still working my around the car and learning what is important and not so important.
    Thanks
    Pacific Paradise QLD
    Service intervals are 12 months or 15,000km WHICHEVER COMES FIRST.
    EG Our car is 3 and a bit years old . has had its 45000km service has about 7000km on the ODO.
    Always use VW APPROVED oils like Penrite Enviro+, Castrol Edge 5w 30LL 504-507 or similar No cheap rubbish
    Sep 2024
    Canberra Australia
    Thanks for that advice, it looks as if the car has been serviced by time - the car will be 4 years old next month with only about 26000km on it then. The dash advice ties in with annual services.
    Garry
    Sep 2024
    Canberra Australia
    Just had the Golf R serviced - 4 years and 26,000km so was given a 60,000km service. As the car is still under warranty I had it done at a dealer - $956 for oil, filter, pollen filter, spark plugs and a brake fluid flush . Brake pads and tyres half worn.
    I asked them if they could turn off the stop start function and the safety message that comes up on the centre screen every few starts but they said it could not be done (maybe they are not allowed).
    So anyone knows if I get a test book like OBD11 (not 2) can I turn these functions off or am I stuck with them?
    Thanks
    Garry
    Depending on the exact car it may be possible to code it out. Around 2020 they blocked it from being done
    Coincides with a change in the model of lane assist camera which went either from a 2Q to a 3Q or other way around.
    I did it on a 19 Tiguan but cant on a 21 Kamiq
    However there is a cheater cable on Ali Express that can do it Cost less than an OBD scanner as well.
    I have just learned to live with it and as in my B7 Passat just lift your foot off the brake a bit and engine will stay on and brake will still hold the car.
    In fact if you learn to lightly brake early and just cruise up to traffic I can get it to never turn off. If it does i just lighten pressure and its all OK Someone on here in your local area should have an 11 and be able to help you
    Sep 2024
    Canberra Australia
    Interestingly having been told that the dealer could not remove he stop start function, it no longer works after the service - a great outcome.
    Garry
    Quote Originally Posted by GarryCol View Post
    Interestingly having been told that the dealer could not remove the stop start function, it no longer works after the service - a great outcome.
    Garry
    The start/stop function will disable for various other reasons (such as a low battery voltage from lots of short drives, battery is dying etc etc) so it could just be coincidence. If its due to battery being low then it should start working again after a decent drive and the battery charges back up to a certain level.
    A device like this one will allow you to default the stop/start system to "OFF" CMT Auto Start/Stop Memory Module for Volkswagen Golf 7.5 MK7 Passat B8 Always Turn On or Off - AA Auto Parts note that you can buy the same thing for about half this price off ebay or Amazon if you have an account.
    Sep 2024
    Canberra Australia
    Hi Lucas - thanks for that information. All systems seem OK so hopefully the start stop function will remain off. However if it doesn't that module that you sent the link for should do the trick.
    Thanks
    Garry
    Jul 2024
    Melbourne, Australia
    Disclaimers can definitely be updated with an OBD11.
    Disable warning "For your own safety, please follow traffic regulations at all times
    1. Module 5F
    2. Adaptation
    3. Search "Function_configuration_hmi"
    4. There are settings for on/off for both "hmi_inital_disclaimer" and "hmi_legal_disclaimer"
    Quote Originally Posted by timmo View Post
    1. Module 5F
    2. Adaptation
    there are quite a few other ones as well
