Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Service Interval Golf R 7.5
    Erskineville, NSW
    I bought this cable off AliExpress, It's on sale today for $15 and it works great as you can still choose to engage stop/start if you wish.
    I'd suggest you look at a YT vid on pulling apart the trim near the stop/start button prior to fitting...
    Nov 2007
    Depending on the exact car it may be possible to code it out. Around 2020 they blocked it from being done
    All possible changes for the MK7/7.5 Golf found on the interscam can be performed via VCDS. I have certainly done all the all the ones I wanted to make. For the Golf, its only from MK8 onwards that it becomes difficult.
    Pacific Paradise QLD
    I cant get link to open
    Was referring to VW in general as I qualified in the next sentence. Cant do a lot on a 2020 Tig compared to a 2019 and was after they changed the camera model it seems. If they didnt do that on the Gold yes would be Ok
    Nov 2007
    Which was a pointless reply since the thread was specifically for a Golf Mk 7.5.
    Aug 2021
    There were issues prior to the Mk8. There were a number of features locked-out on the 7.5 which were available on the 7, including disabling stop-start. Had this issue on two 7.5s, along with my own car when different datasets from a late model Passat were uploaded to enable certain features via coding.
    Quote Originally Posted by petemac110 View Post
    Cant be right according to another poster, but who is to know unless you try as the block out was introduced without fanfare and affected some cars but not others across the same platform. Was trying to be helpful but sometimes it doesnt pay
    Nov 2007
    Interesting, did Stop/Start disable on a Mk7.5 Golf 110TSI with no issues using VCDS. Though I could not do it on either of the 2 MY23 T-Rocs (which is based on the MK7.5 platform) in the family.
    They are all derivatives of the MQB platform Golf up to 7.5 First gen MQB. Mk8 Golf is the MQBEV.O TROC MQBA1. Kamiq, TCross MQB A0.
    It seems from researching, the introduction of the new model camera they introduced some time from late 2019 and mostly in cars from 2020/21 changed access to the modules and despite being able to do things in the Tig the module access has changed and some simple things cant be done on the cars with the new camera. Like I cant get the speed signs to appear in the dash in the Kamiq but was easy to do in 2019. Some other things like S/S cant be disabled and believe me Ive tried every way known on forums. Even the cheater cable I bought is a bit sus at times
