Results 1 to 6 of 6
Thread: Selecting Reverse instead of First - Manual MY16 GTi
    Oct 2015
    Darwin, Northern Territory, Australia
    Red face Selecting Reverse instead of First - Manual MY16 GTi
    G'Day Gang, I have an issue with my transmission and accidentally selecting Reverse gear instead of First. If I quickly select 1st in about 50% of the actions my car goes into reverse, which if, I'm sitting at the lights, scares the **** out of the car behind me. Luckily there is the beep from the reversing camera to warn me so I don't head backwards. I've had it back to the dealer who says there is nothing wrong but I'm wondering if any one else has such an issue or if it's just my enthusiasm to get it into gear and take off?
    May 2013
    It's quite easy in my MY16 R to think I've taken it out of reverse and in to first to find it's still in reverse. I reckon the collar restrictor is slow to reset. I've not had this issue of selecting reverse from a standstill.
    MY08 Mk5 GT Sport - sold
    Jeremism Guest
    Never found the same issue with mine, even going quickly from reverse to first (MY15 R). The car never felt like i could have popped it back into reverse after it clicked out from reverse, if that makes any sense.
    Apr 2013
    Mine seems fine. Perhaps the spring is a bit weaker than it should be on yours. Do you out of habit push down on the gear stick when shifting?
    Oct 2015
    Quote Originally Posted by Jimi View Post
    I must be but at times when I also move from reverse to first it doesn't come out of reverse.
    May 2013
    Quote Originally Posted by NTPete View Post
    Yep. That's what happened to me. Having said that it hasn't done it for a couple of weeks now so perhaps I have either adapted or it has improved as the car has bedded in.
