Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Sat nav licence agreement always showing
  1. #21
    Quote Originally Posted by fontana302 View Post
    Surely there must be a VCDS tweak to turn this off?
    With BMW's you can (using the equivalent to VCDS), so I reckon there must be a way.
    Fontana: Hello again. Yes, there is a (simple) VCDS tweak to turn-off the "nag screen". The original instructions were provided by Zloybob.
    I've provided a link to Zloybob's tweak in my VCDS reference thread, but here's the "Open Controller" screen shot
    Or, if you want to do it the easy way, here's the long coding helper screen shot of the pertinent byte. It's bye 23 of the infotainment control module (address Hex5F)- remove tick from Bit 2.
    PS: Please note that when I did this tweak, I had to set-up the radio again (lost RDS and TP) . Not difficult to do, just need to be aware that it's a necessary step in the tweak
  2. #22
    bobcrusader Guest
    What's the screen before this? I can't find the screens you are showing?
  3. #23
    Quote Originally Posted by bobcrusader View Post
    Bob:
    From the "Main" VCDS screen (below) click "Select"
    Then click "5F-Information Elect" (see below"
    Then click "Coding-07"
    Then click "Long Coding Helper" - see 1st screen shot on my previous post
    Go to Byte 23 (2nd last byte from RHS) - see 2nd screen shot on my previous post
    Then remove tick from Bit 2
    Then click the "X" on the top RHS of the long coding helper screen
    Then click Doit!
    Then close all the screens
