Results 1 to 10 of 17
Thread: Roll back issues with adaptive cruise control.
    Apr 2014
    All,
    My 1 03tsi regularly rolls back on (even slight) inclines when the ACC brings the car to a stop. It will roll back and then the brakes will bring it to a stop.
    It some cases the car comes to a halt with a very loud crunch. It sounds as if it's the gearbox bringing the car to a stop. Hopefully I'm wrong there and the crunch is the brakes.
    Yesterday the rollback happened and the car rolled backwards THROUGH the brakes. I felt them bite slightly but it kept going back through them. I stopped it myself before I rolled into the car behind me.
    I have taken it back to the dealer and there hasn't been any joy yet. They're not being unhelpful they just haven't seen the issue before and I understand that they have to see it happening if it's not a known fault.
    Is anyone else having similar issues?
    Greg
    MY14 Golf Wagon Highline 1.4L TSI 103, Limestone Grey Metallic, Roof, Leather, DAC.
    Apr 2014
    Thanks for your response.
    I'm not sure you understand how the ACC works. It uses the radar to bring to car to a stop and applies the brakes. The car is most definitely not sitting on the clutch. Not in any way shape or form.
    Greg
    Apr 2014
    At least I think that's how it works
    Greg
    Apr 2014
    Quote Originally Posted by lambertia View Post
    In the manual it clearly states that for a DSG like mine the ACC holds the car with the brakes. This issue occurs on the slightest of inclines. You wouldn't even know you're on a slope (until you roll back). I plan to take it back in tomorrow.
    Greg
    Apr 2014
    Relying on ACC to hold the car in position is fraught with danger if the car in front moves across from in front of you and cruise is set at 100kph You might have an interesting experience as you go past him rapidly.
    That's not how it works. Once the car has stopped and the 3 second restart expired, driver intervention is required to get the car moving again.
    Greg
    Jul 2011
    Have you pressed the brakes? If it's rolling back then hill hold assist isn't working I'm sure it will only work if you press the brakes. If your not pressing the brakes at all you will get roll back. Any DSG will do that.
    If your hearing that crunch its normal function of abs intervening to bring your car to a stop. If means your very close to the car in front.
    Debatable but using acc in traffic is asking for trouble.
    Don't get me wrong I love the tech but its like anything electrical there will always be a glitch. And when you least expect it BANG!!! It's like city assist it only works if you take your eyes of the road. It really should only assist when someone slams there brakes in slow traffic.
    Apr 2014
    Quote Originally Posted by grtuned View Post
    The issue occurs when the car comes to a gradual stop behind the traffic in front. I'm not using the brakes and its not a hard deceleration.
    I agree that some roll back will happen. But not one metre or more (measured by watching the the reflection of the wheels in a window - half a wheel rotation = ~1M). I think that's excessive.
    Not likely related to this - I'm going backwards after all but will be less concerned if the crunch is the brakes.
    ACC can make even Punt Road an enjoyable drive!
    I agree that you always need to keep in control. I am at the stage where I brake if I feel the rollback. However I want to follow through in case there is something wrong with my car. I have take off issues as well (unrelated to ACC) which I'll post in another thread.
    Hence the question if others are getting significant rollback.
    Greg
    Jul 2011
    Hill hold will apply the amount of pressure registered when first operated and continue to maintain that brake pressure continuously every time it activates. So if you only operated the brake lightly then turned on the hill hold every time you stop it will apply that pressure this may be why the vehicle is rolling back even though hill hold has switched on.
    My suggestion is turn off hill hold apply a harder Brake pressure then activate hill hold then seat belt on and take off normally so it releases and monitor
    See how that reacts.
    May 2011
    Melbourne, Vic
    I've had the *exact* same issue.. but noticing it more now than I did before.
    Interestingly enough, we have the exact same spec car (MY14 wagon 103TSI, limestone grey, roof, leather, DAC). I'll have to keep an eye out on the roads
    Are you sure ACC is supposed to actually stop the car?
    I've tried it twice (coincidentally on Punt Rd) and I know for certain I'd have run into the car in front if I didn't brake at the last second myself.
    Manual GTI here.
    2014 GTI | Pure White | Manual | Sunroof | DAP | Dog sleeping on back seat |
