depends if immo is still in the cluster like the golf mk5/mk6. if it immo is in cluster then the dealer will need to be involved. if the immo module is separate such as like the passat then it will be a swap with coding and you will be done..
i did this for my b7 passat in under 30 minutes. cluster seems very expensive, passat full colour mfd cluster was <$500 shipped from europe. also ensure that you have the correct revision cluster as you will need to deal with metric and imperial versions.
