Kevie: Hi - It's been a very long time since I was in Bright-town (fly-fishing heaven
Before you throw your hard-earned dollars at a new set of HID bulbs and before removing various bits on the car - are you sure that the driver-side lamp is blown?
With absolutely no offense intended - the fact that the lamp fails to illuminate does not necessarily mean that the lamp itself is faulty (albeit it could be the lamp). Other possible reasons could be the ballast, the fuse, headlight fitting earth, or wiring/connectors.
