Results 1 to 7 of 7
Thread: Replacement HID Globes
    Feb 2007
    bright town VIC
    One of the HID globes has blown in my Mk7 R and I need to replace it (drivers side). I couldn't find anything in a thread.
    Any recommendations on where to source one?
    iilumo have a good range (Philips or Osram if you want an OEM quality replacement), or their own "Nova" brand if you want a good quality aftermarket bulb.
    Replace both bulbs and keep your existing working bulb as a spare.
    NOVA (D SERIES) : HID / XENON BULBS – iilumo
    Blinkwork Auto is another option: Blingwork Automotive Lighting Australia
    Both shops are in South East Melbourne.
    Kevie: Hi - It's been a very long time since I was in Bright-town (fly-fishing heaven )!!
    Before you throw your hard-earned dollars at a new set of HID bulbs and before removing various bits on the car - are you sure that the driver-side lamp is blown?
    With absolutely no offense intended - the fact that the lamp fails to illuminate does not necessarily mean that the lamp itself is faulty (albeit it could be the lamp). Other possible reasons could be the ballast, the fuse, headlight fitting earth, or wiring/connectors.
    Feb 2007
    bright town VIC
    I thought the ballast and globe were an integrated unit? The car is 7 years old, not sure how long they usually last, but it started flickering for a few days and now if you look it's like one of those plasma balls with a very weak spark. There is a warning light on the dash to say it has failed. Not sure how to verify anything without pulling it all apart anyway and if doing that it makes sense to have a globe available if needed.
    I ended up ordering an Osram globe on eBay for $90 delivered.
    Feb 2007
    bright town VIC
    PS replacing the globe worked. But gee it was a lot of effort to replace. Took half a day doing the "quick" approach.
    Canberra
    I'll bet you're glad you didn't attempt the "slow" approach !!!
    Jun 2018
    Quote Originally Posted by kevvie View Post
    Just done another day and took me 15-20min each side...
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI color cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
