Results 1 to 10 of 16
Thread: Remote key stopped working
    Dec 2015
    NSW
    Hi forum
    One of my remote keys has stopped working. Lucky there's a second one.
    I checked the battery with a multimeter and it seems ok at ~ 2.75 volts, but replaced it anyway.
    There's no blinking red led when any button is pressed.
    Is there some way to "reset" these devices, or is this covered by warranty ?
    TIA's for any tips or clues.
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
    Dec 2008
    Sydney/Canberra
    Has it been dropped, or gotten wet?
    They don't like that.
    There should be a re-sync procedure somewhere online you can try.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2015
    NSW
    Quote Originally Posted by Umai Naa!! View Post
    Neither impact nor water damage. Its been lovingly cared for.
    I can only find re-sync procedures for cars with a keyed ignition switch in the steering column.
    What to do for cars with key-less entry and start ?
    Canberra
    Battery wrong way round ? It is easy to do.
    Or corrosion on battery contacts (possibly from a previous battery that leaked).
    Or (least likely), new battery is also faulty (it happens, particularly with cheaper ones and fakes)
    As a quick fault finding test - take the known "good" battery from the remote that works and try it out in your non-working remote.
    Dec 2015
    NSW
    Thanks for suggestions, but I already tried all that. There's no corrosion, These fobs are like new, except that one doesn't work.
    Feb 2015
    Wollongong
    Quote Originally Posted by bgroper View Post
    If the red light doesn't come on when a button is pressed after putting a known working battery in then its an internal electronic fault.
    It could be the IR transmitter has failed. I'd be pushing your dealer for a new one, how old is the remote?
    Dec 2015
    NSW
    Quote Originally Posted by Imolator View Post
    The car is ~ 18 months old, hence my question in original post wondering whether these key fobs are covered by warranty.
    Nov 2017
    Coffs Harbour NSW
    If they are as new as you describe it should be replaced under warranty. Accessories are covered under warranty with the car, only misuse, damage and wear and tear would void a fob warranty. Neither of those sound the case here.
    2018 Golf GTI DSG (DAP LUX INFO R-TAILS)
    Sep 2012
    What are the chances of both key batteries dying within a couple of days of each other, especially when one is used all the time and the other not at all? Key one died last Thursday when I needed to go somewhere and key two on Saturday when I was one my way to a photoshoot. Luckily they're easily replaced and don't need recoding.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Dec 2009
    Kew, VIC
    Mine both lasted almost five years.
    Replaced them because I thought it was about time.
