Originally Posted by
ziggyboy
I own an MK6 Jetta DSG and do not like it. I prefer to be lazier and drive a torque converter auto without having to worry about whether I'm driving an auto the right way.
The wet clutches in the DQ-250 handle creeping much better than the dry clutches in the DQ-200. Drive your car as you would a slushbox.
Resident grumpy old fart
