LMF: hi. Yours sounds like an interesting project and on any other car except one of VW's MBQ platform vehicles, your approach would be entirely correct. However, VW appear to have made a number of radical changes in these cars, the least of which is their updated design philosophy for lamp protection. In previous models (for both VW and other manufacturers), the familiar fuse box was the source of power for each lamp. But in MQB vehicles, this no longer happens and the role of the Body Control Module (BCM) has been extended to both the provision of voltage/current for (most) lamps and associated fault monitoring. If you look at the fuse box designations on a MBQ car, you won't find a myriad of fuse positions for individual lamps. Instead, the mk7 allocates 2 x adaptation channels (of the 19 x adaptation channels that manage each of the 35 x possible exterior lights) solely to the task of fault monitoring
What does this mean for you project? Well ... I think that it means that you will need to obtain the supply for your new LED lamps from the existing wires in the cabin loom (i.e. not from the fuse box). I've included a cut-down copy of the wiring diagram below that shows how the BCM (VW calls the BCM, "J519") and the footwell lights are connected (notice that a fuse is not involved in the ciruit)
As for OP's very good point about the likelihood of error messages (from the BCM in the case of a mk7) when it suddenly sees LEDs instead of the factory fitted incandescent lamps (I assume), I've included below a table showing how my LED footlights are programmed. I've only shown the critical adaptation channels for the footwell lights as the remaining channels in the Leuchte-set aren't active in my car. Alas, you will need access to a VCDS cable to change these channel settings.
Cheers and good luck with the project
PS: I don't think that the setting for (
6)-Leuchte30FR LC72-Dimmwert AB 30 in the table is critical. From memory, I recall that this value changes with the setting that the driver makes in the infotainment MENU screen - I think
