Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Puddle of water under driver side carpet
  1. #21
    Further update:
    1. The AC overflow pipe was apparently crushed. Possibly from work done by another dealer. They replaced the part.
    2. Volkswagen rejected a warranty claim to replace the carpet.
    Hopefully it dries out enough not to smell, or it'll be going straight back!
    2014 - Mk 7 Golf R in Silver | 2011 - Polo TDI in Yellow | 1981 - Lincoln Town Car in 80s beige
  2. #22
    Dec 2007
    ivanhoe vic
    That's crap they rejected the warranty claim or the other dealer should pay for it
    B6 Passat Wagon No KESSY
  3. #23
    Yeah. We'll wait to see how it dries out. If it doesn't smell, I don't care.
    If it does smell the dealer said they'd go back to them. I suspect they'll approve it if that's the case
  4. #24
    Jun 2009
    Since they aren't going to replace the carpet you should pull it up and get a hair drier on it to make sure you dry the area out as much as you can.
  5. #25
    Quote Originally Posted by team_v View Post
    Its going to be hanging up at the dealership til Wednesday as I'm heading away for the weekend
  6. #26
    Quote Originally Posted by vdubmotorworx View Post
    ?? Who said the evaporator was on the right hand side??? I said the drain tube for it was........
    So you assurt the water draining from the evaporator is piped all the way to the other side of the car to drain? I guess my logic assumed it would be drained like every other vehicle on the same side as the evaporator using the extremely short and direct path thru the firewall.
  7. #27
    Feb 2013
    northern Perth WA
    Bump. Anyone else had this sort of issue? In our Mk7 wagon now 18 months old, we theoretically had leaking roof bar mounts a year back, that shorted out the electrics in the passenger's side footwell and door surround. Now after a bad night's rain, the driver's footwell is sodden, after staying dry thru a week's drizzle. Climate control has remained on a steady 23 all week, so no sudden change there. Dealer suggests the air con drain may be the problem, but it seems very sudden.
    Gotta love VW - if it isn't the engine and DSG blowing up, it's leaking and wet floors, and presumably rusty floorpan if not cured properly.
