Results 11 to 20 of 27
Thread: Puddle of water under driver side carpet
    Mar 2013
    Brisbane QLD
    Quote Originally Posted by NCGR1 View Post
    So the AC evaporator is on the driver's side on a RHD version? I find that hard to believe.
    ?? Who said the evaporator was on the right hand side??? I said the drain tube for it was........
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Quote Originally Posted by armthehomeless View Post
    No idea. The carpet must be fairly water tight. There's definitely a squishy bubble of water there. I'll try and take a video
    "The water doesn't come through the carpet" If it doesn't come thru, where are you feeling "damp"?
    And the AC is above the driver's feet instead of the passengers feet as with our LHD models? That does not seem right.
    Well a bit of water came through to make it damp, but not enough that it flowed through. If that makes sense.
    But the majority of the water was in a squishy pocket under the carpet
    2014 - Mk 7 Golf R in Silver | 2011 - Polo TDI in Yellow | 1981 - Lincoln Town Car in 80s beige
    Apr 2010
    So according to the dealership, the driver door seal has leaked and water went behind the speaker and under the driver carpet. It didn't drain as it was supposed to.
    It must have come through during the storm in Brisbane last Thursday. The car was only in it for 15 mins or so...so seems strange!
    They have to take photos and send them to VW to find out how to proceed.
    Jun 2009
    Hopefully they get back to you quickly and sort i out.
    It was a lot of heavy rain last week but i wouldn't expect the door seals to fail enough to let the water in.
    You don't seem to be having much luck with the car unfortunately.
    Quote Originally Posted by team_v View Post
    I try not to think about it
    And now apparently it was the AC overflow pipe...
    So confused!
    Mar 2013
    Brisbane QLD
    I did say that at the start....
    Mar 2013
    Brisbane QLD
    I did say that at the start....only because ive seen it before
