Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 81
Thread: Post speed sign in active display GTi 7.5
  1. #31
    Jul 2010
    Do you know the security code for ACC Control unit 13 please
    Security code is 14117.
  2. #32
    Pacific Paradise QLD
    Quote Originally Posted by dArK5HaD0w View Post
    Thanks for that. Now can try something else.
  3. #33
    For those that want specific advice go here and join and ask your questions in your models subforum
    Home | OBDeleven
  4. #34
    As OP has said 14117 is the security code for the hex13 module.
    If you, or anyone else needs further security codes, I've posted a table on the Ross-Tech forum HERE
    Hope the table is of use - but more importantly (and my reason for replying) - if anyone knows security codes that aren't on the table (and that have been confirmed as working), please let me know - so I can add to the table.
    I promise to include attribution if advised.
  5. #35
    May 2019
    Perth, WA
    Updated my maps yesterday and did some detailed research on the TSR feature. It appears TSR currently detects only speed signs and
    "no-overtaking" signs and no other signs. This seems the case even for cars coded from the factory. So no use much wrecking our brains.
    I'm now trying to see how I can get the TSR (camera) and maps to work together. I passed a school zone yesterday and TSR detected the 40kph. I then made a left before the school zone ends but the system still enforced the 40kph limit and when I exceeded the limit I started getting warnings on the virtual cluster.
  6. #36
    Exactly as we said
    Best of luck trying to use something that may not be there
  7. #37
    May 2019
    Perth, WA
    I have come across some sites mentioning the following coding as well:
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 - Activate
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus - Activate
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification - Activate
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer - NOT
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off - NOT
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high - NOT
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill - Activate
    In my case I've only done the first three, are the remaining ones necessary?
    Also, I dont find these values in A5:
    Control unit A5 (front / advance camera)
    Adaptation
    Display end of speed limit symbol
    Importance to activate: Display valid additional signs
    View Channel Valid suffix
    Corresponding value: 00100111. (default was 100111)
    Any thoughts?
  8. #38
    Quote Originally Posted by nibose View Post
    Adaptation
    Any thoughts?
    Would help if you state with control module its in. From look of that it is in the MIB unit which will only alter what it shows and not do anything to activate things
    No thoughts mine works
  9. #39
    May 2019
    Perth, WA
    Its control module: 5F for the first section.
  10. #40
    Jul 2010
    my 2 cents worth......
    Australia uses the RoW navigation maps, along with many other countries.
    European countries uses ECE navigation maps.
    TSR in fusion mode does not complain when being using with ECE maps - it appears they have the necessary data for fusion mode to work.
    however it appears the RoW maps are missing the TSR data altogether, hence fusion mode is not happy.
    even if someone had figured out the map structure, i don't know how one would create a set of tsr data, specific to australian roads. i'd imagine this would require some sort of hocus pocus voodoo magic!!
    so, my conclusion would b - no point flogging a dead horse.
    as for pACC (predictive acc), this is a SWaP enabled feature.
    i'm not aware of any VW or Skoda models, in australia, with this feature enabled because of tsr/fusion data being missing from our maps. without this map data, it can't be predictive.
    so again, no point getting it SwaP enabled (good luck with that to start with).
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
