Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 81
Thread: Post speed sign in active display GTi 7.5
  1. #61
    Pacific Paradise QLD
    Quote Originally Posted by Flipper Dog View Post
    The maps on my Audi, Here provided maps similar to Discover Pro, will show in the map the speed while approaching schools zones as 40km/h depending on the actual time of day. Example on Friday I was travelling through the same school zone at 3.50pm which displayed 40km/h, twenty minutes later traveling the same route it was now showing 70 km/h. On non school days there is no 40km/h displays.
    However I don't have TSR activated.
    You say APPROACHING school zones Mine doesnt change till I have passed the sign
    It should be pointed out that there are different brands of units that do different things.
    Also in different makes within the VAG group vehicles have different grades of stuff enabled EG DLA is in current Tiguan Allspaces but not in the standard one.
    Audis seem to have a higher level of equipment , once again dependent on the model and spec level of that model.
    So to compare one against the other is a case of oranges and apples
  2. #62
    May 2019
    Perth, WA
    "The limited sign comes up because of the lack of info in the maps. Its not "fault" just the unit telling you it cant find what it is looking for"
    I'm aware but does it get logged as a fault code is my question? I have seen so in a similar post
  3. #63
    Quote Originally Posted by nibose View Post
    Wasnt in my last scan or any others either Interestingly this morning I went up to where I turn left and it changes to 70 without a sign and I turned right ad went up far enough to see the speed sign for that part of the road It stayed at the 60 as per the sign.
    However on coming back to the corner where it usually changed to 70 (no sign) it didnt so am stuffed IF I know how it gets the speeds at times
  4. #64
    Jul 2010
    BUT how do you equate that theory with the FACT that i posted about our area. No sign on dash till I go past one 800m up road. Turn left onto a road which actually has a 60 limit (I went back up it till I found a sign)
    Unit immediately shows 70 which apparently a few years ago it was.
    Changes to 80 as i go past the next sign then when I go off the slip road it changes to 60 again but is actually an 80 zone
    No rhyme nor reason to that lot
    Also on the Bruce Highway there is about 10km of roadworks signed 80. In the middle of it 60 pops up on the dash and it was 2 years ago before the road works started and the road moved over about 100m sideways from where that exit was
    urs is acting weird, and sound like its operating in Fusion mode at times!! don't know how, but its picking up map data somehow.
    do u have TMC activated? could it possibly, long shot, remote chance, have an influence on the speed being displayed in ur cluster/infotainment? dunno know. doubt it. then again.......
    ur mystery continues.
    no, there is definitely no faults logged. its just a warning, rather than an error/fault.
    with mine, the warning shows up, without fail, after the first 500m of driving, whether or not it sees a speed sign or not.
    then never shows again for that drive.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  5. #65
    Well did it again this morning and a new message popped up Said No traffic signs available then a minute later gave the usual restricted one which it only does once Was because I had the speed sign in centre of AID instead of just in the top row
    Things that could affect it ,,, maybe.
    I have altered a setting to correct my speedo and it now reads perfect at 100kph
    Do have TMC enabled
    Just did the TSR as per the coding instructions.
    I only ever get a single speed sign at a time and it only changes as I go past it not before unless its one of the phantom ones
    If I am overspeed it puts a little exclamation mark on left side of the sign ( have turned the gong off)
    Do have DLA enabled. Had HBA enabled but after doing DLA it seems to have turned that off as I looked in the module and its now disabled
    Have stopstart turned off
    Also altered the steering wheel notification when getting out of lane however it has only vibrated on one occasion and did it all the way for 90km and has never done it before that or after it
    So god knows cos I dont Does anyone elses pick up historic signs that arent there any more
    I notice in 4B which is DLA that predictive route data is enabled Wonder if that has anything to do with it
  6. #66
    May 2019
    Perth, WA
    I'm also interested in enabling HBA, I do have "light assist during rain" option available in the Discovery Pro menu (lights). Not sure of the coding though. My car only has halogen headlamps though.
    @ Hillbilly - enabling DLA will disable HBA as it appears to be included in DLA. to my knowledge, DLA includes HBA, cornering, AFS etc all in one.
    I'm also interested in reducing the size of the speedometer and rpm meter (the two circular ones), giving more room to the navigation pane, as you may have seen in Audi. Is this something possible in VW?
  7. #67
    May 2019
    Perth, WA
    The DLA comes only with the models with LED lights. Mine is the comfortline with DA & DP/Audio package. DLA requires the motors and other systems to move the lights depending on the car level/position (sensed by levelers on the suspension), camera input etc and the AFS control module. These are not present in my car, hence I HBA or light assist is the only possible option. Would you be aware of the coding?
    As for the shrinking of the meters, I wish to transform to the Audi model, as shown in the pic.Post speed sign in active display GTi 7.5-virtual_cockpit2__download-1024x681-jpg
  8. #68
    May 2019
    Perth, WA
    Do you have the exact aid that the Audi has because even the Tiguans latest version isnt like that
    This is the case with most Audi's, A4, A6, Q5 etc
    HBA is on the Auto instruct site and is an App for mine for 100credits in the OBDeleven App on my phone Whether it works for your lights is another thing
    I did not see HBA on Auto instruct. I use VCDS
  9. #69
    May 2019
    Perth, WA
    Dropbox - Audi Traffic Sign Recognition Retrofit Guide rev1.pdf - Simplify your life
    I just came across this link which gives information on TSR on Audi with Fusion mode. Has anybody tried these steps?
  10. #70
    . I use VCDS
    Well there is the problem as we have been talking about using OBDeleven and now you say you are using something else
    Also as the thread is about TSR I will comment no further about lights as its well off topic
