Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 81
Thread: Post speed sign in active display GTi 7.5
  1. #41
    Pacific Paradise QLD
    Yes a good explantion I knew that stuff was missing in Aus maps but you explain it better than I could \ ANd yes we are chasing something that isnt there and Im pretty sure it wont see "No overtaking" signs either.
    Why Well coming into our village we have a standard roadsign with 10 on it It never notices it because it wont be in the maps but there must be some speed signs in them otherwise they wouldnt change at places where there have been previously but not any longer.
  2. #42
    Jul 2010
    Quote Originally Posted by nibose View Post
    It appears TSR currently detects only speed signs and "no-overtaking" signs and no other signs.
    i forgot to mention earlier - this is how it shows "no-overtaking" on mine.......
    Post speed sign in active display GTi 7.5-tsr-jpg
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  3. #43
    Must be different on the Skoda then as that hasnt appeared in my Tiguan but then I dont have it in the centre of the AID and my aid has all the other stuff in totally different places.
    Will try it but dont know where to find a no overtaking sign anywhere near my home.
    Am confused as you show a Skoda but this is the Golf Forum??????
    We are all mixed up
  4. #44
    May 2019
    Perth, WA
    Quote Originally Posted by dArK5HaD0w View Post
    Is it possible for you to share your coding? Just trying to understand what could be different in the Golf! How does TSR work in your case, in roads where there are no signs, does it take from the maps?
    We are all mixed up
    VW, Audi & Skoda use same set of engines/transmissions and control modules, the variants change depending on the model, so its okay to have a Skoda owner share his input.
  5. #45
    Except I think the Skoda has a Bosch unit in it and thats the difference as has already been explained
  6. #46
    Jul 2010
    We are all mixed up
    nothing to b mixed up or confused about.
    as nibose already mentioned - we all share the same internal organs, we just have different shells & body panels on the outside.
    yes, on some occassions, there might b slight differences between the control modules, but vw and skoda r essentially the same. audi have variations given they sit on a different platform.
    this is the A5 Front Sensor (Camera) version fitted in my Skoda:
    Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
    Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
    Component: MQB_B_MFK H06 0231
    mine is set to "road sign detection". if there r no road signs picked up, nothing is shown in the cluster/nagivation.
    before i had TSR enabled, it would display the speed signs based on map data.
    with TSR enabled, fusion mode shows nothing for me. road sign detection works, albeit in "restricted mode".
    i haven't tried the horizon one.
    below is the coding i used.
    Post speed sign in active display GTi 7.5-tsr-coding-jpg
  7. #47
    Yeah same for me fusion doesnt work but am trying to enable it in module 13 ACC but cant find the right access code as the one given doesnt work 14117 wont work.
    The OBDII guys reckon it wont do anything so will see if i can ever get into it
    There is as well subtle differences between vehicles despite all being on the same platform.
    Some things work on some and not on others or are enabled in different modules so not an exact science is it
    Other things are enabled in one model but not another
    EG DLA is standard on a Highline Allspace but not on a shorty same s**t just a different bucket
  8. #48
    Jul 2010
    wat coding/change is in Module 13-ACC that is TSR related?
  9. #49
    There is places where you can activate Road sign detection and other bits like predictive ACC but it isnt in the software AFAIK
    However I dont know if any of it will male any difference and cant find out till i get the right security code
  10. #50
    May 2019
    Perth, WA
    A clumsy question: Suppose you're driving along a road and there's a school zone (40pkh), the TSR display this new limit. You make a left immediately before the school zone is over. The new road has a different limit, assuming there are no signs present, does the cluster display an over speed error? or does it display a new speed sign based on the map data?
