Originally Posted by
Hillbilly
Eskys are for use on hot days so kind of ruins that argument.
You shouldn't be running a fridge of one of those circuits anyway as the current draw is mostly too high for the gauge of wire installed at factory.
I had an 8 Gauge wire running to the rear of my vehicle to run the 60L fridge I ran.
Always remembering that smart things in vehicles have to be engineered to cater for the lowest common denominator.
Hillbilly: As you can see from the pic in my tweak, the protecting element in the circuit is a 20Amp fuse. Whilst the same fuse appears to be used for both the in-cabin and hatch boot power sockets, I would think that the capacity of all of the upstream components (i.e. wiring, connectors, relay contacts etc.) in the ciggy lighter circuit would be rated at 20 Amps.
Assuming a fully charged battery with a nominal voltage of 14V, this means that an Esky attached to the power outlet could draw up to 280 Watts (or there abouts) and still not trip the fuse. I agree that this calculation assumes ideal conditions (i.e no voltage drop at the power socket outlet and ideal fuse characteristics), but it gives an indication of the permissible power-draw from this circuit. Personally, I'm not sure that I would be comfortable running this type of load in the boot of my car whilst the vehicle was left unattended and with the engine switched-off for any length of time. But, perhaps I'm being too conservative
