Originally Posted by
flight
dv52 - I can't help wondering if any other functions can be similarly tweaked. For instance, if it were possible to reposition a fuse in order to deactivate the stop/start system that is hated by some owners. When deactivating the function by depressing the switch, the switch is illuminated by power from somewhere, so would applying power directly have the same effect and might this be achieved by moving a fuse? Your thoughts?
flight: I do like the way your brain works -but, that's all the hagiography that I intend to give! (only kidding)
Seriously, it would be great if such a thing were possible. The way that I envisage that the SS console button works is that instead of providing a fixed 12Volt supply to the appropriate on/off control mechanism, the switch provides a "leading edge" to the control mechanism (i.e the console switch provides an AC signal, rather than a DC supply). That's why (I think) that the car resets the status of SS to the off position each time that the ignition is turned-on. But, I admit that I'm just guessing.
If anyone can find that elusive "quick-fix" for disabling SS, then he/she will have my undying admiration (worth lots at the check-out desk at Coles/Woolworths)! But as I have implemented the VCDS tweak for SS, this annoying little VW feature has not been a problem.
