Results 11 to 20 of 34
Thread: Park Assist / Park Pilot - Questions and Issues
    Dec 2013
    Thanks guys. My dealer told me he's never used it before so is not sure how to do it, but he'll find someone in the service dpt who can help me.
    Sent from my SM-G925I using Tapatalk
    Nov 2009
    Quote Originally Posted by Kiaorana View Post
    Hey guys, when I started my car on my way back from work, it said "park pilot is currently unavailable" and the reverse camera doesn't start when in reverse. I stopped the car, restarted it, same issue. Any clues what it can be?
    The system may not have initialised correctly on startup. If you stop the car and leave it for a half hour, the system should have shut down and may come back fine on a subsequent start. Give that a go.
    Kiaorana: interesting handle -I assume you are from the Cook Islands and you are saying "Hello", or perhaps you are using the Maori word for the same term. In any event, Hi in return!
    Regarding your Park Pilot problem - the reason for the message could be that you have not set-up Park Pilot in the car's MENU correctly.
    Unless you tick the box that says something like "activate automatically", Park Pilot can only be engaged by pressing the "P" button on the centre console.
    Just a hunch, but it might be prudent to check the following:
    1. Press the CAR button on the escutcheon plate on the RHS of the infotainment system
    2. Press Set-up on the lower RHS of the screen (looks like two gear wheels)
    3. Select parking and manoeuvring
    4. Make sure the box next to activate automatically is ticked under Park Pilot section
    5. Exit all menus
    Aug 2013
    Hazel Glen
    My Mk 7 is in the shop for exactly the same thing. Reverse bay parking, If it sees a spot it chooses one with a car already there..
    Reverse parallel is fine.
    So it probably is the car.
    Dec 2013
    Hi Baz, thanks for letting me know, I'll take it to the shop. Let me know if that fixed your issue.
    Dec 2013
    5. Exit all menus
    Hi Don,
    Sorry I didn't see your reply earlier! You're right KiaOrana comes from the Cook Islands where I grew up!
    Park Pilot is configured properly, it's definitely a car issue. It always tries to park in the bay with a car, instead of the free bay.
    Have a good one!
    Jun 2009
    Western Australia
    Hi Don,
    Have a good one!
    Hi Kiaorano,
    I had a play with the auto park system today and it also tried to reverse me into spots where cars were already parked.
    Not ideal!
    Sent from my GT-I9505 using Tapatalk
    Dec 2013
    Interestingly, I took my car to VW where they cleared a fault, and since then, the park assist works perfectly.
    Jun 2009
    Western Australia
    I had another go last night and it worked fine on that occasion. If it does it again ill notify the dealer next time I'm there.
    Jan 2013
    Brisbane, QLD.
    Did they get a technician to go out and demonstrate with you/ you show them?
