Thanks guys. My dealer told me he's never used it before so is not sure how to do it, but he'll find someone in the service dpt who can help me.
Sent from my SM-G925I using Tapatalk
Kiaorana: interesting handle -I assume you are from the Cook Islands and you are saying "Hello", or perhaps you are using the Maori word for the same term. In any event, Hi in return!
Regarding your Park Pilot problem - the reason for the message could be that you have not set-up Park Pilot in the car's MENU correctly.
Unless you tick the box that says something like "activate automatically", Park Pilot can only be engaged by pressing the "P" button on the centre console.
Just a hunch, but it might be prudent to check the following:
- Press the CAR button on the escutcheon plate on the RHS of the infotainment system
- Press Set-up on the lower RHS of the screen (looks like two gear wheels)
- Select parking and manoeuvring
- Make sure the box next to activate automatically is ticked under Park Pilot section
- Exit all menus
My Mk 7 is in the shop for exactly the same thing. Reverse bay parking, If it sees a spot it chooses one with a car already there..
Reverse parallel is fine.
So it probably is the car.
Hi Baz, thanks for letting me know, I'll take it to the shop. Let me know if that fixed your issue.
Hi Don,
Sorry I didn't see your reply earlier! You're right KiaOrana comes from the Cook Islands where I grew up!
Park Pilot is configured properly, it's definitely a car issue. It always tries to park in the bay with a car, instead of the free bay.
Have a good one!
Interestingly, I took my car to VW where they cleared a fault, and since then, the park assist works perfectly.
I had another go last night and it worked fine on that occasion. If it does it again ill notify the dealer next time I'm there.
Sent from my GT-I9505 using Tapatalk
