BBS CH BLACK
Specs: 19 x 8, ET50, weight 25.3lbs/11.5kg
Tyres: 235/35 R19 Dunlop Sportmaxx
Details: Milltek development vehicle fitted with Eibach Pro-Kit springs
Attachment 11185
Attachment 11186
Attachment 11187
Always a big fan of the CH but unsure if it works on the Mk7, and thinking the silver finish may work better on the darker color. At least on the black CH the stainless lip protector provides some definition to the wheel.
BBS CK
Specs: 19 x 8, ET44, weight 26.2lbs/11.9kg
Tyres: 235/35 R19
Attachment 8977
Attachment 8978
AUDI HYBRID TURBINE
Specs: 19 x 8, ET42, weight tbc
Details: KW coil-overs fitted
Attachment 9036
Attachment 9037
The Turbine design is fitted to a number of different hybrid models in the Audi range in varying sizes, these appear to be off the Q5. 20 inch versions also available although OEMs would be very rare, no doubt reps will be available however.
BC FORGED HB27
Specs: from 18 x 8 to 21 x 11, ETxx, weight tbc
Details: unknown lowering
Attachment 9050
Attachment 9051
Attachment 9052
BC Forged wheels are made from forged T6061 aluminium and are made to order to your specifications, so it appears a Golf friendly width and offset can be arranged. Not a cheap option with these wheels around $US4000 but there are some cheaper alternatives. Some great designs and finishes, if you're bored have a drool at BC Forged Wheels USA - PYSpeed Automotive Multi-Piece Custom Wheels Built for Every Car Application
VW MOTORSPORT
Specs: 18 x 7.5, ET51, weight 23.1lbs/10.5kg
Details: optional fitment from dealers
Attachment 9067
Attachment 9069
A couple of snaps of VWW cars - diesel_DSG's white TSI and MIRSAD's PP GTI (hope they don't mind me including their cars here).
VW INTERLAGOS/TURBINE
Specs: 18 x 8, ET41, weight tbc
Attachment 9078
Attachment 9079
OK, I am by no means advocating crimes against good taste by chucking orange wheels on to a white car, so I've toned it down in picture two. These wheels are fitted to some Passat CCs locally, but also appear on European Scirrocos as well. OEMs crop up now and then but reps will be easier and come from numerous sources, and numerous finishes. Even found a set on EBay UK fitted with Falken tyres for $1,250 (excluding shipping and any import costs).
LAMBORGHINI CALLISTO
Specs: 19 x 8.5, ET42, weight tbc
Details: assuming 4 x Gallardo fronts used, rears are 19 x 11, ET55; H&R suspension kit
Attachment 9082
Attachment 9083
Attachment 9084
Attachment 9085
Nothing like a set of exotic wheels on a Golf. Using genuine wheels won't be cheap, although surprisingly seems to be quite a few odd lots floating around on eBay so tracking down four genuine fronts may be possible, although would require some major work to fit. Also available as reps in more favourable fitments.
Note: not a legal fitment in Australia
KRAFTBERG 'VOSSEN VVSCV3' REPS
Specs: 19 x 8.5 (f) 19 x 9.5 (r), ET45, weight tbc
Details: H&R coil overs fitted
Attachment 9092
Attachment 9093
Gold on red hmm. Don't know anything about these actual wheels, but the original Vossens look beautiful and come in silver, matte graphite and machined matte black. The 19 x 8.5s do come in ET45 so could be made to fit with a little work and minus that rear end poke! I did a quick calculation and the Vossens would land here with duties/taxes for around $3,300.
VW ROTARY
Specs: 18 x 7.5, ET51, weight tbc
Tyres: 225/40 R18
Attachment 9094
Attachment 9095
Attachment 9096
Attachment 9097
Another factory option on the Golf which is similar to the Motorsport but has a different spoke design and is finished off in anthracite. The car featured is another VWW member, cathaldinneen.
ROTIFORM SNA
Specs: 19 x 9, ET40, weight tbc
Details: H&R development car at 2013 SEMA, H&R Street Performance Tuner coil over
Tyres: 225/35 ZR19
Attachment 9112
Attachment 9113
Attachment 9145
These Rotiforms are a custom brushed finish with matte tinted clear centers and brushed low gloss clear lip. The standard machined finish can be imported here with duties/taxes for around $2,200; a custom finish can be quoted and ordered from Rotiform in the USA. The 19 x 9 ET40 will need some work to fit however.
Here are the new Oettinger 2014 MK7 Specific rims due in Australia mid year:
New RS
New RX
RXX Redline Gloss
RXX Redline Matt
RXX Silverline
You get the idea
ABT DR
Specs: 18 x 8.5, ET50, weight tbc
Attachment 9123
Attachment 9144
OZ SUPERTURISMO LM
Specs: 19 x 8.5, ET44, weight tbc
Attachment 9132
Attachment 9142
Hopefully some better pictures show up of this or other cars running the OZ ST LMs. I'll admit my bias having fitted them to my Mk6 - I've guessed the specs on this car as these definitely look to be 19s - this won't be a legal fitment. However the 18 x 8 ET48s I had on my Mk6 are fine (although lowered I got front end rub.. fender screw mod probably would have fixed this), you can even go with an OEM sized fitment of 18 x 7.5 ET50 if you like and save a couple of dollars.
Speaking of which if you're after OZ and weighing up the local v overseas options I've found the local option weighing up pretty well still (as it did last year when I bought for my Mk6). PM for further info if desired.
OZ FORMULA HLT
Specs: 19 x 8.5, ET47, weight tbc
Details: KW coil over suspension
Attachment 9133
Attachment 9134
Attachment 9143
While the above might not be quite legal, as per the ST LMs there are friendly 18 x 7.5 ET50 and 18 x 8 ET48 fitments available. These wheels, finished here in grigio corsa with centre cap, also come with exposed bolts, and a matt black finish with or without centre cap.
VW NOGARO
Specs: 18 x 7.5, ET tbc, weight tbc
Attachment 9178
Attachment 9179
Attachment 9180
The Nogaros are the standard 18 inch option on the European GTD - the 19s option are Santiagos a la GTI. Can't find an offset but would assume somewhere in the 49-51 range in keeping with standard OEM fitment. Not a bad looking wheel but might be tough to track down - not to be confused with TSW Nogaros or Rial Nogaros which are both completely different styles of wheel.
AUDI RS4
Specs: unknown reps
Attachment 9182
Attachment 9183
Attachment 9184
This is a TSI Comfortline running RS4 reps in 18 inch. The design doesn't look too bad on the Mk7 although the arch gap here looks wrong. The original thread on this car suggested it may have still been sitting high due to the transport blocks. Plenty of original and reps options in all kinds of specs on this wheel.
ATS DTC
Specs: 18 x 8.5, ET tbc, weight tbc
Attachment 9210
Attachment 9211
Attachment 9212
Not easy tracking down information on these ones, they have been fitted for use on the VW Castrol Cup cars and won't be a legal fitment on Australian road cars. FYI the series takes in Czech Republic, Germany, Poland, Slovakia and Hungary in tuned Golfs running GTI badging but an R style front bar (the pictured car is a road car, not the race car). For €39k drivers get a maintained vehicle for the seven round 14 race series although it appears they can offset some of that cost be on selling advertising spots on the car.
Attachment 9213
What is easier to track down is the ATS Racelight wheel which I think looks great, the straight lines should work well with the Mk7 styling. Available in a few finishes, but likely in a very unfriendly and not legal fitment of 18 x 8.5 ET30. Hopefully this comes up in something more useful to the Golfs in the future.
Attachment 9214
VW TALLADEGAS
Specs: 19 x 8, ET50, weight 28.2lbs/12.8kg (tbc)
Tyres: 235/35 R19
Attachment 9215
What are our thoughts.. Mk6 R Talladegas on the Mk7?
VWR
Spec: 19" x 8.5mm with 235 tyres.
It's also on the VWR springs. We removed the top fender screw and there is no rubbing anywhere, even 4 up.
Attachment 11232
