Page 130 of 779 FirstFirst ... 3080120128129130131132140180230630 ... LastLast
Results 1,291 to 1,300 of 7787
  1. #1291
    Quote Originally Posted by AdamD View Post
    These are a great rim, Mk6 or Mk7! (y)
    No disagreements here.
    As are CH-Rs (18 x 8.5, ET47):
  2. #1292
    VW MOTORSPORT - REVISITED
    Specs: 18 x 7.5, ET51, weight 23.1lbs/10.5kg
    The Official Mk7 Wheel Thread-golfvwms1-jpg
    The Official Mk7 Wheel Thread-golfvwms2-jpg
    The Official Mk7 Wheel Thread-golfvwms3-jpg
  3. #1293
    Dec 2014
    [QUOTE=Dutch77;1115178]These aren't a bad looking wheel, not sure exactly what they are although they are similar to Vossen CV3s. Obviously this is a stance fitment at 19 x 9.5, ET35 in conjunction with KW V1s:
    I'd go as far as to say they they are either a 10 or 10.5 width to get that amount of concave...
  4. #1294
    Quote Originally Posted by DUB32 View Post
    They definitely have a very concave look, although in this instance the owner/someone who knew the owner posted the actual specs as quoted with the pics at 9.5.
  5. #1295
    Going for the bumblebee look with Cadiz finished in a matte black:
    The Official Mk7 Wheel Thread-golfbee1-jpg
    The Official Mk7 Wheel Thread-golfbee2-jpg
  6. #1296
    Dec 2014
    Can you kindly point me in the direction of said owner/someone knowing owner to confirm as I am interested in finding out more for my own car setup.
    Regards
  7. #1297
    PM sent.
    Sounds interesting - I hope we get to see the final set-up?
  8. #1298
    Feb 2015
    Can you actually fit 10.5 wheels in a Golf R? Wow!
    I was thinking of going for a 9.5. No stance just want wider tyres for grip.
  9. #1299
    Quote Originally Posted by Mila View Post
    I'm sure someone has, or someone will.. but you're talking about massive work to make that work.
    Even at 9.5 you're unlikely to make that fit legally - that Golf R wasn't even close to being ok here.
    If you're looking for grip, and not stance, than I am guessing performance is your main goal so I'd be looking at going light weight and something in 8 maybe 8.5 wide only. Obviously you'll save a bit by looking at 18 x 8 over 19s, but you're call on what will meet your needs. There's quite a few guys tracking on here so should be plenty of good advice in that regard floating around.
  10. #1300
    Feb 2015
    North Shore of São Paulo State, Brasil
    hi
    I've been reading almost the whole thread, yet, I am quite hesitant to buy and install some Audi S6 replicas, 18 x 8 ET 45, I think they could poke a bit inside the wheel arches, and according to Will They Fit, the wheels will poke more 2,5 cm to the outer part, compared to the 16 x 6,5 Dover originally fitted
    so, my plan B is the Amarok "Durban" replica, curiously the name of those from Golf, but a different wheel, they're 18 x 7 ET 42 which will poke just 1,0 cm out
    also their center bore is 57,1 fitting exactly, without center adapter rings
