[QUOTE=Dutch77;1115178]These aren't a bad looking wheel, not sure exactly what they are although they are similar to Vossen CV3s. Obviously this is a stance fitment at 19 x 9.5, ET35 in conjunction with KW V1s:
I'd go as far as to say they they are either a 10 or 10.5 width to get that amount of concave...
Can you actually fit 10.5 wheels in a Golf R? Wow!
I was thinking of going for a 9.5. No stance just want wider tyres for grip.
I'm sure someone has, or someone will.. but you're talking about massive work to make that work.
Even at 9.5 you're unlikely to make that fit legally - that Golf R wasn't even close to being ok here.
If you're looking for grip, and not stance, than I am guessing performance is your main goal so I'd be looking at going light weight and something in 8 maybe 8.5 wide only. Obviously you'll save a bit by looking at 18 x 8 over 19s, but you're call on what will meet your needs. There's quite a few guys tracking on here so should be plenty of good advice in that regard floating around.
hi
I've been reading almost the whole thread, yet, I am quite hesitant to buy and install some Audi S6 replicas, 18 x 8 ET 45, I think they could poke a bit inside the wheel arches, and according to Will They Fit, the wheels will poke more 2,5 cm to the outer part, compared to the 16 x 6,5 Dover originally fitted
so, my plan B is the Amarok "Durban" replica, curiously the name of those from Golf, but a different wheel, they're 18 x 7 ET 42 which will poke just 1,0 cm out
also their center bore is 57,1 fitting exactly, without center adapter rings
