Thanks. I did a lot of research and calcs and yes it is a good fit with no issues
I'm running on 18s - OZ Leggera HLTs, 18x8 ET48 so not fitment issues at stock or lowered I would expect.
Well done Wezza, I am a fan of the Watkins Glen and at one point even put out a WTB feeler before settling on my OZs again - I couldn't find a used set, and the new set from the USA was overpriced. IIRC the Glens are 18x7.5s so you shouldn't have any issues, confirmed by nma.
Have you taken the car out into the country for a spirited drive? We'd had confirmation x8.5 ET50 was still ok, I thought x8.5 ET45, particularly with the wider rubber, might get a bit of rub now and then.
I know on my Mk6 I would not get rub around town or highways, but I would on sharp cambered corners when pushing on a bit.
I might need to visit then..![]()
Cheers Dutch,
Searching every evening finally paid off, managed to get these for a steal with only 2000k's travelled on them they're pretty much new. I remember Guy H saying that his GTI lowered on VWR springs with 19x8.5 et51 got a bit of rub up front so a couple of wheel liner screws were removed to alleviate the problem. Might find a few rub issues show up later once the springs settle in?
PAST: 88' Mk2 Golf 16v GTI & 97' Mk3 Golf VR6
CURRENT: 13' Mk7 Golf 103 TSI Highline
I have thrown everything at the car bumps ,dips , sharp corners ,with me alone and 3 passengers all good. It was important to me because I don't like things that don't fit properly I suppose I am a. Bit anal that way I love my cars so it has to be right
Sat not a good day for me perhaps another option to help you .
I think running on 18's and I'm assuming 40 series the ride with eiabach would be similar to stock I'm pretty sure they have the same if not similar spring ratings but I'll check that for you if you like
So far i can't praise the ride quality the Eibachs deliver. It will be very interesting for me going for 17's with abit more rubber, to 18's with a lower profile. I'm hoping there won't be a huge difference in comfort.
