Was bored and tried to swap wheels with my brother. These are 18s I forgot the specs, after a hard time trying to get one wheel off, I realized the bore on his wheels aren't big enough for my bolt and.... Wasted our time
The ride quality of your original set up is far smoother my nephew has the same vehicle the eiabach spring rating is definitely a lot firmer
GTI PP Mk7
My grandma used to say...
No stock at oz Italy for the leggera 19"x8" until October so I've cancelled order,I don't want the et47 8.5"width versions because I'm not planning on touching the ride height and not so keen on the poke look,now looking at other brands.........,
Ok let me know if I can help out
Very much liking these in this colour also as grey is available,just checked with wheelbase and they are checking stock in Germany,come in at £1050 in the uk compared to £1700 for the oz leggera they are also flow formed and not a bad weight either,hmmm
**EDIT now ordered**
Great to hear, well done. Definitely want the pics up once fitted.
Given the OEM fit of those wheels and the extra clearance on the Mk7 there should be no rub issues at all.
Good to hear, it's useful information for this thread and others looking at similar fitments. You're one of the first, along with Wezza, to post your findings on the lowering issues. Much of the commentary so far has been a bit of guess work and visualisation. Much appreciated.
If it was stock like I'd be all over it.
Our first thread test fit (excluding me balancing a set of Ultraleggeras on reams of paper).. I love it - even if it wasted your time it's good to see.
Congratulations, look forward to seeing these on and some different angles. Great to see the thread helping contribute to a purchasing decision. Must admit I like the design of these and being Borbet they will be decent quality. Assuming as suspected they take the stock VW cap I'd be tempted to keep it OEM looking and do this.
thanks for this thread I would of never even of thought about fitting these borbet's just by looking at them on there own,i did a bit of digging on that R with them on,it's been lowered 25-30mm and has 15mm spacer on the rear and 10mm spacers on the front.i still think they will look good on my standard r though?
Really? It doesn't look lowered by that much over stock. I reckon your car will look fine, spacers can work well with lowering (illegal here in Australia) but I reckon a car looks a bit lower visually if the wheels are tucked a little - it's why say a Highline can look ok on 17s but look a bit stilted on wider 18s-19s. I reckon even my car appears to have more wheel gap with the after market wheels than the Austins (and it's only 7mm extra poke).
