NEUSPEED RSE52
Specs: 18 x 8, ET45, weight 19.0lbs/8.6kg
There is a permanent group buy on Neuspeed wheels in the USA with details previously posted here: The Official Mk7 Wheel Thread . Just a reminder these are a decent quality light weight wheel, a few different styles, finishes and sizes available and these can take the VW centre cap for an OEM finish.
^ they're a little on the heavy side but DAMN! That looks good.
^^ My goodness they look amazing!!!
19 x 9 et52, With 35mm drop. Would that work without arch mods or too close?
PAST: 88' Mk2 Golf 16v GTI & 97' Mk3 Golf VR6
CURRENT: 13' Mk7 Golf 103 TSI Highline
The extra width on the outside should be ok/marginal depending on how much the drop cambers the wheels - it's 16mm poke over a GTI wheel which was borderline in previous discussions in this thread. However Avdo is correct, there is a real issue on the inner clearance which will be 22mm in (compared to GTI) - IIRC that's well over acceptable, admittedly I'm going by Mk6 standards though.
I think you'd need to be more like ET40, which is probably more common to in x 9 wheels, but you're then at 25mm poke on a GTI which will definitely require work on the front, and probably the rear as well.
There are cars running as aggressively as that on this thread, just need to invest to make it work.
(Note I know you're not in a GTI but my visuals/measurements are based on my own car so I find it helps me to reference back to that)
