Dat file name tho
Anyone got a suggestion for what to do with this gutter rash on my Cadiz?
Unsure if there's anyone in Sydney/Wollongong who can repair this well enough, or of I should just get them all painted gloss black. Got a limestone grey R with the alloy look mirror caps, unsure how gloss black is going to integrate with rest of the trims...
I do like the stock Cadiz but I'm unsure how good the repair will come out.
I know the pictures are quite small and will add bigger ones. Essentially just want to show the spread of the rash. No enormous chunks out, they were relatively gentle gutter counters. Cheers!
Pinched from the post - who knew searching Mk7 Golf Grass would return a favourable hit.
<rubs hands> Best way to justify a good set of wheels!
Seriously, those can be fixed up fairly easily to an 'acceptable standard', although black Cadiz can work - you'd need to try it out and see how the mirror caps work.
I think because there is still a mix of black and chrome finish on the front and rear (pipes) the caps are still ok as is.
