Page 35 of 779 FirstFirst ... 2533343536374585135535 ... LastLast
Results 341 to 350 of 7787
  1. #341
    PLATIN P58
    Specs: 17 x 7, ET38, weight tbc
  2. #342
    RONDELL 49
    Specs: 19 x 8.5, ET50, weight tbc
  3. #343
    PORSCHE 5 SPOKE 'LOBSTER CLAW'
    Specs: 19 x 9.5, ET46, weight tbc
    The Official Mk7 Wheel Thread-porsche2-jpg
    The Official Mk7 Wheel Thread-porsche3-jpg
    The Official Mk7 Wheel Thread-porsche1-jpg
    Note as these are Porsche wheels with a 5x130 PCD an adapter would have been utilised.
    Note: not a legal fitment in Australia
  4. #344
    MSW 24
    Specs: 18 x 8, ET45, weight tbc
    MSW is made by OZ Racing.
  5. #345
    Sep 2010
    Perth
    Does anyone know the most aggressive offset i'll be able to get away with on 19x8 or 8.5 wheels, with Eibach springs fitted without having to pull or roll the arches?
    PAST: 88' Mk2 Golf 16v GTI & 97' Mk3 Golf VR6
    CURRENT: 13' Mk7 Golf 103 TSI Highline
  6. #346
    Guy was running VWR x 8.5 ET50 on VWR springs early in this thread and said no rubbing even with load.
    Dropping below ET50 would likely see some rub up front unless the camber was played with.
    Should be able to go lower on offset up back as the rear guards are fairly generous on the Mk7.
    Avdo was at ET44 and has no rub on stock R suspension, the Eibachs would be lower but if they do tuck the fronts a little then may be able to get away with it.
    Obviously this thread does feature much more aggressive fitments than this but those cars will also feature heavily worked suspension adjustments as well.
  7. #347
    The front fenders have a screw located at 12 O'Clock (same as the MK5 / 6 models), so depending on tyre profile, you can bend this in / remove it if it's your sole point of contact.
  8. #348
    OZ SUPERTURISMO LM - REVISITED
    Specs: 19 x 8.5, ET44, weight tbc
    The Official Mk7 Wheel Thread-ozst1-jpg
    The Official Mk7 Wheel Thread-ozst2-jpg
    The Official Mk7 Wheel Thread-ozst3-jpg
    A little personal bias creeping in again on the OZs. Note that the car in the third pic would be running 18 x 8 ET48s.
  9. #349
    DIEWE TRINA
    Specs: 18 x 8, ET40, weight tbc
    Another German brand with a reasonable selection of wheels: DIEWE WHEELS - Startseite . These five spokes are also available in 17 x 7 and 19 x 8.5 and numerous different finishes, as pictured in 18 x 8 will set you back around $1,800 ex UK including freight, duties and taxes.
  10. #350
    INOVIT HASTE BLACK
    Specs: 19 x 8.5, ET45, weight tbc
    Had a comment made "I'd like to see these on a Lapiz Blue R....think it would look good", so here is a quick photo chop:
    The Official Mk7 Wheel Thread-inovit-golfr-jpg
