The 18 x 8 ET45 wheels should be perfectly fine on a Mk7 unless there is something different with your specs as I notice you are in Brazil.
I am running 18 x 8 ET48 right now and have plenty of room still - generally anything up to x 8.5 ET45 is considered ok on the Mk7 to sit on the wheel arch.
VAG motorsports project Golf R
Still not a real fan of the Oettinger rear wing but the gloss black finishing around the car offset with the white does work in this instance.
I wonder if they've wrapped the rear valance to finish it in gloss or whether it's just the way the lights reflect. The mirror caps definitely need to be finished off in gloss black though IMO.
And more aggressive round pipes > oval.
thank you Dutch77 for the quick reply and also for the fantastic effort in this thread
later I will try to post some photo editing work that I've done with the options I have, and I will ask for your opinions
thank you
best regards
