Page 21 of 31 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 302
Thread: The Official Mk7 Golf DSG / Clutch / Shudder / Squeal Issues Thread
  1. #201
    It does tend to happen when accelerating .. however I believe the rattle sound is caused when the wastegate acuator rod vibrates so any movement in that area can potentially cause it to make the tinny sound. The clip basically mutes it.
    So you can picture it - https://www.google.com.au/search?q=w...DMMyaPXufjM%3A
    Can't recall if mine made the noise when off the throttle though, sorry.
    RS
    R
  2. #202
    Feb 2014
    Central Vic
    Sounds like the engine flexing and some part of it contacting a cross member or something similar but only under engine braking.
    Is it worse the lower (and more severe) the the gear selected?.
  3. #203
    Feb 2014
    Central Vic
    Is the mount, that handles the engine reverse torque, done up .....
    Everthing tends to be done in a hurry and the odd screw/nut/bolt might be missed.............there shouldn't be anything left over however
  4. #204
    Oct 2012
    Tasmania
    ryeman, when I say off acceleration I maybe didn't explain that well.
    Say I'm in d mode going up a slight incline at 80kmh the car will be in d6/d7 if I take my foot off the pedal I get the rattle.
    The same rattle that happens when accelerating from a stand still at low revs.
    It only seemed to happen in d mode too, at low revs. I drove it around in sport and it didn't make the noise at all....
  5. #205
    Feb 2014
    Central Vic
    Ok, just a thought.
    If you can 'play it' like a tune, and at will, you/someone can usually diagnose the problem's location.
    If it's on a hoist, giving the exhaust a thump with your fist will tend to show up any looseness also.
  6. #206
    Oct 2012
    Tasmania
    The mechanic has ordered the clip for wastegate rattle. Hopefully that's what it is and solves the problem.
  7. #207
    Oct 2013
    Brother in law had a knocking/rattling sound when the car was idling or driving off at low speed. we eventually found one of the engine mounts was completly undone! can't understand how that could have happened .
  8. #208
    Sep 2010
    Southern Highlands NSW
    DQ200 7sp dsg 3yr or 5yr warranty?
    Hi all, i just took the wifes car for a drive after she complained that the car was doing strange things on take off. After a quick spin i found a very noticeable shudder on take off when switching from 1st to 2nd gear in D mode. When i tried in S mode and manual mode i couldnt replicate it but it did appear when put back into D mode. Anything heavier then a light take off the car shudders pretty hard.
    Ive called the dealer up to book it in asap but my question is regarding warranty, is it 3yrs or 5 for the dsg box? this car hit the 3yr mark in october of this year so im hoping that the dsg is covered for 5yrs.
    I daily a mk6 gti which is also a dsg and its been faultless, we have 8 VWs in the family all being dsg with only our Caddy diesel being a manual. None have given us as much trouble as this mk7 has grrrrrh
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
  9. #209
    Apr 2011
    Depends on when you ordered your car.
    Golf brochure with the 5 year warranty: http://www.eaglehawk.com.au/download...-web-final.pdf
    Golf brochure with standard warranty: http://www.eaglehawk.com.au/download...g-warranty.pdf
    Basically, it seems end of July 2013, they switched back to standard warranty. But that doesn't mean anything if they sold it to you with what appears to be standard 5 year warranty. Good luck.
  10. #210
    Yes the 5 year warranty deal was for a short term period at the height of the (false) DSG scares.
    VW actually told me 'we are dropping back to three years because if we keep it at five people will think something is wrong with it' - I would prefer to have bad thoughts and peace of mind myself.
    How many of the other DSGs in your family group are six speed/wet a la your GTI v the seven speed/dry box? Unfortunately that's where the problem may lie.
