Page 12 of 31 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 302
Thread: The Official Mk7 Golf DSG / Clutch / Shudder / Squeal Issues Thread
  1. #111
    Melbourne, Victoria, Australia
    Had my TSI104 Golf serviced at 45K. A wk later my gearbox has started to thump when cold starting btwn 1 and 2, sometimes 2 to 3. Havent rang the dealer yet. I'm guessing I will need to asap reading these posts.
    MY13 Golf TSI 103 White
    Rotary 18" Wheels Front, Side, Rear and Roof Spoiler.
  2. #112
    Is it normal to have a slight shuddering/vibrating feeling from accelerating from a very low speed in gear 2, especially when turning a corner? It's definitely slight, but it's noticeable in the right conditions. Otherwise the gearbox is great.
    I have the 7 speed DSG in my 2009 118TSI with the clutch pack replaced 12 months ago. I'd be fine if it didn't get worse, as this this my 3rd clutch pack on this car.
  3. #113
    Nov 2009
    Quote Originally Posted by Matticus View Post
    That's how it starts. I had the clutch pack replaced on my mk6 118TSI three times in 4 years and 110.000km. My wife's Golf 7 90TSI had the same symptoms from about 22.000km, now at just over 30K it's awful and needs replacement on the next service.
    Nothing has changed from Golf 6 to Golf 7, exactly the same issue with the clutch packs. You can expect to get anywhere between 20-30.000km out of the clutch pack, before it needs replacement. The cost is from memory about $2k.
  4. #114
    Quote Originally Posted by Stelex View Post
    Thanks Stelex.
    You'd think with several iterations of the clutch pack and various software updates that they'd be better by now. I should have warranty for another 12 months for the pack (proving it to VW is another story), but I will probably sell the car in 6 months and avoid all of the hassle.
  5. #115
    Feb 2016
    NSW
    Weird squeaking noise when going from stationary
    I have a 3 year old 103TSI that has only run 11,000km. Recently there has been a weird squeaking noise when the car goes from stationary. My friend told me that it sounds like the clutch is slipping when it shifts gear. You can listen to the noise below:
    https://www.dropbox.com/s/188xolwlcm...B1%5D.mp3?dl=0
    I'll bring my car to the dealer to check but I reckon it's going to be difficult to show them the problem as it only happens after about 30 minutes to 1 hour of driving the car.
    What do you think the problem is?
  6. #116
    Dec 2012
    Sutherland Shire, Sydney
    If the clutch was slipping it would do it in 1st when you drive off and you would see the RPM higher than the road speed
    Clutches generally don't squeak unless they have worn completely through the friction material
    It's a funny little noise, does not sound like a clutch (or even a release bearing)
    Is it a manual or DSG?
  7. #117
    Nov 2013
    AUS
    Definitely your clutch. Happened to me a while back b/w 2-3 gear shifts, occurred a bit after 6000km. Never affected drivability at all but I made sure the clutch got replaced. The sound disappeared following the clutch replacement. Your dealer should be requesting to keep the car for a day or two to allow them to replicate the issue if it only occurs after a prolonged drive. Keep us updated.
    You can follow this thread here, download my audio file and you'll see it sounds exactly like your squeak.
    http://www.vwwatercooled.com.au/foru...ml#post1076980
  8. #118
    Aug 2015
    Sydney, Australia
    I'd say it's your car crying because it's basically just been kept in a garage for 3 years. The Official Mk7 Golf DSG / Clutch / Shudder / Squeal Issues Thread
    How did you manage to only do 11,000kms?
  9. #119
    Feb 2016
    Another Mk7 DSG with shudder
    Hi, I purchased a Mk7 90TSI DSG7 plated September 2013 new from the local dealer.
    The car now has 84,000km on it.
    It had been running superbly until around the 60k mark where I noticed a shudder start to develop.
    It has not worsened to date but i think i should have it dealt with before the warranty runs out.
    It is a work car so I do around 35k a year in it.
    The shudder:
    Seems to always occur at very low revs and when engine is under load. -particularly a cold engine
    Example: Slowly reversing out of my driveway on an incline.
    Slowly accelerating away from a stop on an incline.
    I generally drive with zest so the shudder is rarely felt. Seems like when you use the semi-auto mode everything is fine and dandy.
    What is far more annoying than the shudder is the rattle from the wastegate clip. I had it fixed at 30k nut it returned at 60k. Need to fix it again at next service which is in a week.
  10. #120
    Mar 2016
    sydney
    3rd clutch pack?! wow these cars... you'd think with all the free warranty repair VW complete they could just build a stable reliable car.
