Haven't had any judder for the last 5 days as it's been cool and only short drives, dropped it off this morning and got a base model 90TSI as an overnight loaner with 1200km on the clock. Software seems slightly different and a bit cluncky changing down into 2nd and 1st but that could be the box has adapted to numerous drivers giving it a caning.
Service adviser also said a new larger spigot bearing comes with the new clutch pack which helps with heat disipation.
Apparently earlier spigot bearing's affected tolerances as the clutch heats up in stop start conditions and contributed to clutch judder.
Valvster
- You may not post replies
- You may not edit your posts
Forum Rules
