If the clutch was slipping it would do it in 1st when you drive off and you would see the RPM higher than the road speed
Clutches generally don't squeak unless they have worn completely through the friction material
It's a funny little noise, does not sound like a clutch (or even a release bearing)
Is it a manual or DSG?
