Quote Originally Posted by GeckoZAO View Post
also make sure RDS and TP are enabled in settings. you should be able to see 'TP' on top of the centre display once enabled.
but even if you can see TP, you may still not able to retrieve traffic information, then thats due to coding.
cheers, thanks. Both settings were off. It works now. I wonder if the satnav takes it into consideration when calculating routes? If not then its pretty useless.
