Results 21 to 30 of 37
Thread: OBDeleven killed Lane Assist
  1. #21
    Jun 2024
    Canberra
    I had a Polo reset after a BCM failed and it cost $450 roughly to get it done in QLD Wasnt needed to go back to the dealer Eurocarupgrades did it along with replacing the module etc. They have shops in other cities so look them up
    None in Canberra, but we have a few European car specialist. One is VW specialist so going to them for advice.
  2. #22
    Jun 2024
    Canberra
    As anyone tried this app in workshop OBD11? Could this reset coding as it says?
    Multimedia Restart
    Current value 0 credits
    About app
    Reboot the vehicle's multimedia system after coding changes or when the system freezes
    Functions
    Restart the multimedia unit
    I thought support would’ve told us to try it if it would work. Still haven’t heard back from support all afternoon/night.
  3. #23
    Jun 2007
    Sydney, Australia
    That will only restart your MIB unit, won't do much to any coding changes.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  4. #24
    Pacific Paradise QLD
    Well looking through the APPS for my Kamiq almost all of them have a white bar at the top of the instructions with a"SELECT VALUE" in it, so that if you have enabled something and it isnt working you go back into it and select "off" and it reverses what it has done. Has always worked for me as it usually doesnt work if car hasnt got necessary hardware or access to modules etc. If it doesnt work the little circle doesnt go green.
    Sudden thought are you using an Android phone or a Devils Spawn Iphone piece of crap.
    Was the same in the Tiguan and I made a few muckups early on before i got into coding properly. However the APP always reversed its self and nothing was amiss. So dont know why it hasnt got that in the APP.
  5. #25
    Jun 2024
    Canberra
    So OBD11 refunded me my used credits but still haven’t heard anything from support.
    When checking lane assist plugged into car it had option to return to original setting, this wasn’t the app I used but will it return to original settings again. The app I used still only has active, so can’t reverse. Don’t use it people it’s not worth 400 credits and didn’t even work.
  6. #26
    Quote Originally Posted by PAPERBOY View Post
    What phone are you using is the most important question Unless you answer that there can be differing results and views on the problem
  7. #27
    Jun 2024
    Canberra
    iPhone 12 Pro, but have access to a 14 & 15 iPhone if needed.
  8. #28
    Jun 2024
    Canberra
    Once again I’ve asked OBD11 for human support and crickets! Northside Euros said they can fix on VCDS but the VCDS guru is on leave till August! Just my luck. It’s booked in on 13th August to hopefully return it back to normal again. Fingers crossed!🤞
  9. #29
    Get an Android phone and try it as Iphones are limited in what they can do.
    The whole system was built for Android and ported across to Apple and never has worked as well.
    So while you muck around with a semi crippled phone you could do it properly on a real one.
    Even an Old S6 like I use sometimes is better that an any Iphone. Until you try that you are just whistling in the wind
  10. #30
    Jun 2024
    Canberra
    iPhone has worked in the past for us on other OBDeleven apps just not this one. So trying an android phone and wasting another 400 credits with no guarantee it will work either, so I’m still sitting in the same boat. OBD11 should be supporting me to rectify the issue and no response from them still. Not even a simple email saying we’re looking into it.
