Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 103
Thread: Number Plates on the Mk7
  1. #21
    Nov 2009
    SEQLD
    Quote Originally Posted by n0d3 View Post
    Exactly what Brendan said, there is nothing on the back. You/the dealer needs to drill holes. Lakin provides a template (you'll need to measure to centre your plates anyway). You can always just stick it on with some tape and do it yourself if you're afraid the dealer might stuff it up.
    My last Golf the dealer didn't get the rear plate centre. So this Golf I told them I want to be there when they attach the plates. I took in a tape measure and got them perfect and he drilled/screwed.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  2. #22
    Mar 2014
    Thanks to all for the info in this thread. I spoke to Philip from Lakin who is extraordinarily helpful and professional.
    In summary:
    GTI and R are shipped with a wide front baseplate (drilled to suit European plates, way too wide for standard Qld plates); dealers will fit normal plates onto this baseplate.
    The rear of the car is completely pristine. Dealers will drill holes into this panel(and usually deeper into the bodywork of the frame) to fit standard plates.
    Lakin make custom plates for the Mk7. The rear is easy: drill small holes through the panel, fit baseplate, attach plates with or without covers (recommends do this yourself, don't trust dealers).
    For the front, he makes a baseplate to fit the predrilled holes, which protrudes 75mm each side of standard plates (as in the photo above) OR you can buy (expensive) custom colored plugs to fill these holes, and drill narrower holes for a perfectly fitting baseplate to match plates with or without covers.
    I will go for the wider plate as in the photo.
    2014 Mk7 GTI​|Pure White|Manual|Tint
  3. #23
    Apr 2013
    What is the benefit of forking out for a bracket for the rear? I would have thought you just attach the number plate directly - simple, clean, flush (and free!).
  4. #24
    Jan 2012
    Epping, NSW
    The rear is to hide ugly holes, and provide a good solid base for the plate protector to mount to over the top of the plate. Also so if you use Euro size rear plays, the mount can go into slimline hole separation so you don't have to have holes at the outer extremity of a Euro plate and no way to hide if you go slimline later.
  5. #25
    Mar 2014
    Also, the flimsy two-point upper attachment (of Qld plates, at least) results in significant vibration and/or rattle against the panel. Screwing the plate directly on is also more likely to damage the paintwork over time. A rear baseplate means the plate is not flush, but combined with a protector cover looks much better IMO
  6. #26
    Nov 2009
    Quote Originally Posted by Jimi View Post
    The photo above is of my car. I also have a rear bracket, and as Tony says, it's there to provide a better base for the numberplate, but also to provide another mounting surface should you wish to fit different-sized numberplates in the future without drilling more holes in the bumper. It's virtually invisible behind the plate though; here's a photo showing the rear bracket from the side (click on it to get the full-sized original and look at the plate up-close):
  7. #27
    So if I am attaching full sized Euro plates to my vehicle, am I right in saying I don't need to worry about the front (as this will mount directly to the VW bracket), but I may wish to consider a bracket for the rear to avoid wide drill holes and paint work damage if I was to ever end up with smaller plates on the car?
  8. #28
    Mar 2014
    @Dutch77: That sounds accurate. I can highly recommend giving Philip at Larkin a call; he is very familiar with the current models and can chat about the best approach with full size Euro plates front and back (if you are planning to get a protective cover, it may fit more snugly with his baseplate). Very helpful and sensible man!
  9. #29
    Erskineville, NSW
    Just mount your plates with double sided tape. No drill holes required.
    I managed about 3 years before I had to re-do it
  10. #30
    AU
    If you decide to sell your car or change plates of different sizes (with Lakin brackets) you can easily swap the base and not worry (the holes are chosen to fit the smallest plate size). CT69 has summarised everything in this thread, if in doubt just call Philip.
    And attaching the number plate directly, if it rattles it'll probably ruin the paintwork.
